12-03-2014, 02:42 PM | #26 | |
Re: Rear vibration ...need help,suggestions
12-15-2014, 11:08 AM | #27 |
Did you fix this problem yet ?
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
12-15-2014, 11:36 AM | #28 | |
Nope, I've been sick for the last few weeks and haven't really felt like messing with it. I put my big tires back on it and have just been driving it.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
12-15-2014, 03:07 PM | #29 |
Can you physically see a hop in the wheel if you sit it on jackstands and run at idle? Maybe the bead is not set right on the tires. Just went through this with mine and it ended up being a bad wheel balance. I had to literally stand there while the machine ran to ensure a good balance. All is good now.
71 C-20 Custom Camper California Truck |
12-15-2014, 09:37 PM | #30 |
rob, I had almost the same problem, I chased it and chased it, like you did. what it turned out to be was the rear axle didn't have enough limited slip additive, so I added one bottle of the additive, and it fixed the problem...so if you're running straight 80/90, with a posi unit, be sure to add the additive , and enough of it...
hope this fixes your problem, and for sure let us know when you do solve it.
Twin Turbo 64 nova project http://67-72chevytrucks.com/vboard/s...d.php?t=669163 68 camaro LS2/T56 vs. 06 GTO build http://67-72chevytrucks.com/vboard/s...d.php?t=516310 project incredible hulk build http://67-72chevytrucks.com/vboard/s...d.php?t=269754 project big red build http://67-72chevytrucks.com/vboard/s...d.php?t=342165 project "blue ray" build http://67-72chevytrucks.com/vboard/s...d.php?t=405465 |
12-16-2014, 04:16 PM | #31 | ||
12-16-2014, 10:24 PM | #32 |
The shop that rebuilt my differential said to use 2 bottles of Fords additive. The say it better than AC delco stuff
12-16-2014, 11:34 PM | #33 |
Ship it to me with a gas card, I don't care how long it takes I'll figure it out! Lol.
Good luck |
12-16-2014, 11:41 PM | #34 |
Does it happen after the rear brakes get warmed up ? Sticking caliper/warped rotor? Emergency brake hanging up?
Axle bearing? |
12-17-2014, 10:27 AM | #35 | |||
I spent 15 years flying military helicopters and you become very attuned to every sound and vibration.....maybe it's in my head and I'm overthinking it.....
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 12-18-2014 at 11:50 AM. |
12-17-2014, 10:37 PM | #36 |
Does it hop with these tires?
12-18-2014, 10:14 AM | #37 |
Any ford dealership should stock it. Its 6$ CDN. I had problems with the CRseal posi additive. As soon as the truck got warm it would bind up going around corners. The ford additive solved that problem.
12-18-2014, 11:49 AM | #38 | ||
http://shop.advanceautoparts.com/p/k...ive#fragment-1
