Old 12-17-2014, 10:29 PM   #1
cerial
cerial's Avatar
metal dash
Anyone ever toss your dashpad and lay down metal. I am looking for ideas on what looks good before I roll something that ends up scrapped.
cerial is offline   Reply With Quote
Old 12-17-2014, 11:29 PM   #2
Just call me Sean
Just call me Sean's Avatar
Re: metal dash
They stopped making all metal dashes when they figured out metal doesn't feel too good against your skull in the event of a crash.
Does sound neat though. I'd like to see what you come up with.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 12-18-2014, 12:20 AM   #3
enaberif
Re: metal dash
DIY4x makes one for our trucks.. Not cheap by any means .. and honestly I'd be more worried about the massive steering wheel leaving a dent in my head than the dash..
http://diy4x.com/cart/index.php?rout...product_id=148
enaberif is offline   Reply With Quote
Old 12-18-2014, 12:27 AM   #4
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: metal dash
64_66 dash fits pretty easy
Old 12-18-2014, 01:26 AM   #5
cerial
cerial's Avatar
Re: metal dash
That diy4x dash is what I had in mind fora shape if I made it. I have a few 4x8 sheets of aluminum, a roller, and could get my hands on a brake easy enough. I think I could bend one up for mock then take a sheet to a shop to have it cut before bolting it down.
Another idea is to toss the gauge cluster, pad, ac, and radio and weld in everything smooth then cut out stuff. This would give some curvature and was more of something I want to see if possible.
Old 12-18-2014, 04:15 AM   #6
Just call me Sean
Re: metal dash
I was thinking more of my little girl in the passenger seat.
Old 12-18-2014, 06:51 AM   #7
andrewmp6
Re: metal dash
Really any dash will work if your willing to make it work cutting and fabing.
Old 12-18-2014, 12:10 PM   #8
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: metal dash
I second what KQQL IT said, the 64-66 dash is a very easy swap. I put one in my truck with very minimal fab. It's maybe a half day job.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 12-18-2014, 04:14 PM   #9
Bears63
...just another truck junkie..
Bears63's Avatar
Re: metal dash
KQQL IT and Tx Firefighter, do either of you have pictures of a cab with a 64-66 dash installed? I would love to see that. Seems to me I would like that dash layout much better.
Mike "Bear" Shea
Bears63 is offline   Reply With Quote
Old 12-18-2014, 05:29 PM   #10
Tx Firefighter
Re: metal dash
It's a very easy swap. I had to build two little filler pieces for the ends. I just used a piece of cardboard to make templates, cut them, tack welded up at the windshield seam and bent it by hand to shape as I tack welded downward.
The windshield rubber hides the seam on the front edge so there's no need to do bodywork there.
Old 12-18-2014, 05:49 PM   #11
Bears63
Bears63's Avatar
Re: metal dash
I really like the looks of that! I think I may have to start some future planning.....
Mike "Bear" Shea
Old 12-18-2014, 07:21 PM   #12
cerial
cerial's Avatar
Re: metal dash
That looks tons better then I expected.
Did the vents spread the heat enough. What did you do for a radio?
Old 12-18-2014, 09:14 PM   #13
cerial
cerial's Avatar
Re: metal dash
The bracket that reinforces by the brake that connects to the dash. Did you bend it or did it line up?
Old 12-18-2014, 10:04 PM   #14
slotard
Re: metal dash
I like it. How hard is pulling the dash? The local Pick N Pull got a '64 truck of some sort (they don't say what) the other day, I might go grab it Saturday.
edit: and what's a good set of gauges to use with it?
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 12-18-2014, 10:20 PM   #15
Tx Firefighter
Re: metal dash
I used an air saw to remove the dashes. They are welded in place so you have to cut them along the windshield pinch weld.
I don't run radios in my trucks so that why my air suspesnion stuff is located where it is.
I'm no where near a pioneer in this swap. There's about half a dozen other guys here that did it before I did.
Old 12-18-2014, 10:27 PM   #16
slotard
Re: metal dash
Damn, Pick N Pull around here doesn't allow power tools. Guess I'll need to find someone with a truck.
Did you weld it into the square body or what?
1973 C20, 350/350
Old 12-18-2014, 10:57 PM   #17
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: metal dash
Guy o bought my dash from drilled all spot welds. Wwelded to the pinch weld
Old 12-18-2014, 11:01 PM   #18
slotard
Re: metal dash
Roughly how many spot welds? I think some power tools are allowed, but grinders aren't. I could probably drill them out with a cordless drill depending on how long it would take.
1973 C20, 350/350
Old 12-18-2014, 11:15 PM   #19
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: metal dash
A bunch 18 maybe. I did mine 4/5 years ago
I saw one on ebay $200 maybe the pics may show
Old 12-19-2014, 12:08 AM   #20
Tx Firefighter
Re: metal dash
A cordless sawzall would do it super easy on one battery with plenty to spare. .
But, me, I'm a stubborn son of a b1tch. I'd make a 3 dollar hack saw blade handle work if I had to.
Old 12-19-2014, 12:20 AM   #21
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: metal dash
How did you attache the side of yours?
Old 12-19-2014, 12:22 AM   #22
slotard
Re: metal dash
Sadly I don't have a cordless sawzall. I'm not sure they allow them either. I'll have to try with the drill, 18 holes isn't horrible if they drill ok.
1973 C20, 350/350
Old 12-19-2014, 01:26 AM   #23
Gregski
Gregski's Avatar
Re: metal dash
lets not forget decapitation due to the reinforced hoods where they over buckle when you open and close them
Gregski is offline   Reply With Quote
Old 12-19-2014, 01:29 AM   #24
Gregski
Gregski's Avatar
Re: metal dash
DIY4x makes one for our trucks.. Not cheap by any means .. http://diy4x.com/cart/index.php?rout...product_id=148
man that's fugly
Old 12-19-2014, 01:30 AM   #25
Gregski
Gregski's Avatar
Re: metal dash
you did an awesome job, that looks amazing
