Old 12-19-2014, 01:55 AM   #1
Classic Bowties
Always on the hunt...
Re: WTB: Power Steering Pulley
Originally Posted by Cash3481 View Post
I need a power steering pulley Like the one pictured here.
Here is the number off the pulley: 993325DJ
The one I have is on the pump in the back that's painted. I need the one in the foreground that has the cone style pulley.
I could go to the junk yard and search for one but I'd rather get it right and headed this way tomorrow if someone has it already.
Please let me know if you've got one you'll sell.
Hey Mike, I think you missed a digit in your above p/n. The stamped p/n should be #3993325DJ which is commonly found mated up with the add on outer crank drive pulley #3751232BB on the small block swp setups. Good luck on the hunt, Mel.
Classic Bowties is offline   Reply With Quote
Old 12-19-2014, 02:06 AM   #2
Classic Bowties
Also just as an FYI, your black pulley on the painted pump setup looks like a #5537 pulley and if so could be sold as/used on the BBC SWP remote fill pump setup mated up with the add on outer crank drive pulley #5525. Mel
Old 12-19-2014, 08:01 AM   #3
Cash3481
Loves all GMC trucks
Cash3481's Avatar
Thank you Mel! I did miss the extra number. I have what I thought was a set of correct pulleys but I don't want the extra add on pulley. Could I bother you for the correct pulley number that will work with the triple lower crank pulley setup? In my haste to get the correct pulley, I was blinded by what I thought was correct. Either way thanks for the assistance.
Mike
If your helping someone and expecting something in return... your doing business not kindness!
Cash3481 is offline   Reply With Quote
