#26 | |
Re: R12 Conversion to R134A?
Its another one of those 2° tricks that alone isn't much but you add that 2° with the 2° you get from straightening all the condenser fins and the 2° you get from this or that and you're seeing the difference between cool and cold. |
#27 |
Understood; thank you -
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#28 |
I just rebuilt my system and used some of the great tips I got from folks on here. I did end up getting a new compressor (not rebuilt), and a new crossflow type condenser. It was hard to find the condenser and cost about $40 more but it seems to work well, and fit right in the stock location. One other note: I rented the vacuum and gauges from Auto zone, got my money back but it was about $350 .
Scott 87 Chevy 2WD SWB, 88 4x4 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=610652 |
#29 | |
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
#30 |
![]() Join Date: Jun 2009
Subscribed
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
#31 |
I'm surprised nobody has mentioned the effects of using a high output electric fan to augment lower AC temps @ lower engine speeds. This is where the use of an electric fan shines vs. a mechanical one with regards to low speed AC performance.
#32 |
Best source of info I've found is the forums over at ackits.com
If you convert, be SURE you have ALL of the R12 oil out, and I'd recommend new hoses for several reasons (better materials, not aged, get rid of old oil, etc).
My Chevy Truck Project Build Thread '62 Ranchero - 200 I6, 3-on-the-tree, power nothing. '71 LeSabre - 455 Stage 1, power everything. |
