What's it worth?
1970 c20. Solid doors, fenders, inner fenders, grill and bedsides. Metal bed has rust through at the cross member between the wheel wells, tailgate is toast, the rad. support has rust at battery case. Has aftermarket 16' aluminum rims. Is blue/white and trim is missing. Interior the seat is torn on the drivers side and the dashpad needs replaced. Dash is uncut. Has guages that work, no tach. Engine is 350 and has had a Edel. 750 put on it with performer intake and cam of unknown lift/duration. Does not smoke. Has 4 speed. Owner says he can get stock intake, rocker covers and air cleaner assembly that came from it.
What do you guys think. Sorry no pics.
68 1 ton dually 292, 2001 Sebring, 2004 Trailblazer, 11 Camaro Convertible. |
go bucks!
around here,.....in the cond. that you have described i'd say between $800-$1300 tops. miamisburg is a suburb of dayton,ohio. 'bout 45 min. north of cincinnati.
'68 swb 1/2t 350/350th '86 lngbd 3/4 TON parts getter '49 gmc 1/2 t 5 window 350/350th '96 gmc sonoma sle ext-cab. hey it's a 4cyl. 5 spd and good on gas y'know? |
Around Camden that truck might bring about $1000.
praise God in everything you do! |
