Old 12-21-2014, 03:00 PM   #1
E.D.75GMC
E.D.75GMC's Avatar
Any tips on making paint stick on tailgate band?
Well as you can see the paint just peels off. I primes it before I applied it and I did it indoors so it was warm.
E.D.75GMC is offline   Reply With Quote
Old 12-21-2014, 03:04 PM   #2
pontgta
pontgta's Avatar
Re: Any tips on making paint stick on tailgate band?
Primer? A scuff then a good epoxy primer then the paint....
pontgta is offline   Reply With Quote
Old 12-21-2014, 03:32 PM   #3
mike69c10
chrome doesn't hold paint well. It needs to be scuffed so that it has some tooth to hold the primer. Primer and paint need to be the same brand. Tape the area, scuff the chrome (scotchbrite), prime (might even use a self etching primer), seal, scuff, paint. Using the same type of paint and primer are probably the two biggest things as it looks like your paint is crinkling and lifting which is usually caused by miss matched paint/primer but could also be caused by poor prep ie. not using a wax/grease remover like prepsol.
mike69c10 is offline   Reply With Quote
Old 12-21-2014, 03:51 PM   #4
E.D.75GMC
E.D.75GMC's Avatar
Okay thanks guys I have a little project to do tomorrow now!
Old 12-21-2014, 05:07 PM   #5
LilD
LilD's Avatar
X2 on the tape, scuff, self etch, scuff and paint.
LilD is offline   Reply With Quote
Old 12-22-2014, 08:20 AM   #6
homemade87
Looks like your primer reacted to the paint. I never use primer under a spray can paint unless I am trying to smooth out a surface and even then its only spot primed . As long as you have a good clean surface those spray can enamels will stick to anything . ( Note the word clean ) . If you use a primer under the color coat when you peal the tape off you will most likely see the primer on the edge . Scuff it a little and paint it .
homemade87 is offline   Reply With Quote
Old 12-22-2014, 08:55 AM   #7
xole
xole's Avatar
What about just using the vinyl lettering instead? Any sign shop could make it or I think LMC has it in red.
-D
'86 Chevy K10 SWB Custom Deluxe 4x4
'94 Chevy Corvette
'07 Ford Mustang
'08 Lexus LS 460
xole is offline   Reply With Quote
Old 12-22-2014, 05:20 PM   #8
E.D.75GMC
E.D.75GMC's Avatar
Okay I'll pull the tailgate band off and off and get to work cleaning that red paint off and whatnot. Also, this yellow was the original paint on it but I obviously painted over it. Anybody know the name of this yellow? I may take it back to original.
