Old 12-14-2014, 05:09 PM   #1
Jimal
Jimal's Avatar
Mirror location measurement
My truck came with a pair of poorly mounted late model design aftermarket mirrors. I purchased a pair of correct aftermarket mirrors from LMC, but before I invest in rivet nuts and the tool required to install them, I'm not absolutely sure that the original mounting holes aren't there, covered by a layer of filler.
Before I start randomly drilling holes, what should I expect? I'll poke through my shop manuals, but so far I've been a bit disappointed with both the '63 manual and the '65 supplemental for stuff like this. I know from other pictures approximately where the mirror would be mounted, but can someone give me a measurement from the door edge? Thanks.
Jimal is offline   Reply With Quote
Old 12-14-2014, 06:00 PM   #2
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: Mirror location measurement
Sorry only have 60-63. If you take your inner door panels off you'll see the plates up in the corner.
Old 12-14-2014, 06:55 PM   #3
Jimal
Jimal's Avatar
Thanks for the scan. That actually doesn't look that far off.
Old 12-14-2014, 09:48 PM   #4
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
yes, take off the inner for exact location.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 12-20-2014, 03:06 PM   #5
Jimal
Jimal's Avatar
I had to ballpark things a bit, because of the differences in the doors between the years, but I think it came out okay.
I will probably end up sticking on some blind spot mirrors when it gets a bit warmer out. But between these and reinstalling the inside mirror, I'm not blind out the back anymore.
Old 12-20-2014, 07:18 PM   #6
aerotruk63
aerotruk63's Avatar
They used these up into the 80's
Old 12-21-2014, 01:52 PM   #7
61K10
61K10's Avatar
Jimal--where did you get your grab handles? how are they attached? I put the same mirrors on mine, does yours vibrate while driving?
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 12-21-2014, 04:21 PM   #8
Jimal
Jimal's Avatar
The handles were on the truck when I bought it. I haven't driven the truck yet, so I don't know whether the mirrors are going to shake.
