Old 12-22-2014, 02:12 PM   #26
68C15
blood type; Retumbo
68C15's Avatar
Re: Timing problems 5.7 VORTEC HELP!!!!!
It's not "base timing". It is called "cam offset". Zero degrees is ideal but they allow +/-4. Warm engine to operating temp, watch "cam offset" in data stream, bring RPGs ro 1000 and adjust by turning distributor. While you're in there with the Verus take a look in "misfire data" to see which cylinders are missing
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 12-22-2014, 02:15 PM   #27
roserangercustoms
Right on, the book for this is nealy impossible to find, been using a chevy p/u book.. Ill let u know how she do thanks again
roserangercustoms is offline   Reply With Quote
Old 12-22-2014, 03:15 PM   #28
95 S_Trucker
95 S_Trucker's Avatar
w4500, I'm assuming that's an Isuzu NPR with a GMC emblem.
The engine is the exact same as the engine in a pick up. The only exception is oil pan and oil pick up. All The info in the chevy Book will be accurate. We worked on several NPRs.
95 S_Trucker is offline   Reply With Quote
