Old 01-25-2004, 10:40 AM   #1
bagged91
Out draggin'
bagged91's Avatar
Question Reskinning Sub 3rd Door????
Anyone ever reskin the 3rd door with a new replacement skin for the FRONT pass door???? As you can see in the attached pic, mine is hurt a little too bad to just pop out the dent but it has no rust at all in the door.
Do you think it would work??
91 GMC Xcab LB-Bags/bd/caddy clip SOLD
72 C10 Cheyenne Super LWB SOLD
92 GMC K1500 Burb
72 C10 Burb (ex. Cheesewagon)SOLD
72 C20 Burb parts truck
71 C10 Burb "project"
bagged91 is offline   Reply With Quote
Old 01-25-2004, 02:24 PM   #2
Dan72cst
Dan72cst's Avatar
I haven't done it, but have been wondering the same thing. In your case, I don't think you have anything to lose. Might as well give it a try and if it doesn't turn out you'll be in the same spot that your in now...looking for a third door.
Here is a picture of mine. The bottom tub thing is rusted so I need to take the door apart to put a new bottom tub in the door, and the skin has some long dents across the bottom. Do I put a new skin on while I have the door apart to put the bottom tub in?
Marysville, WA (Dan72cst@hotmail.com)
72 4wd Blazer CST 350/350
72 4wd Chevy LWB 350/350
68 2wd Chevy LWB 327/400
Dan72cst is offline   Reply With Quote
Old 01-25-2004, 05:01 PM   #3
7T1BURB
Reskinning the 3rd door
.....is an option. However, remember that the Suburban 3rd door is not as wide as the pass or driver doors. This plan would require resizing the new door skin door skin and ensuring that the "new" end is folded and bent over to replicate the rest of the contours. I suspect it would work, but would take some metal fabrication work.....just a though to consider.
7T1BURB
7T1BURB is offline   Reply With Quote
Old 01-25-2004, 08:09 PM   #4
bagged91
Out draggin'
bagged91's Avatar
This is how I was thinking of attempting it. I realize that the front door skin is longer but a cut off disc on an angle grinder works wonders. I did take some careful measurements and it appears that the front skin will line up in the doorhandle area leaving just the front edge to be trimmed. In the photo, I drew a crude dotted line where I would trim the original skin, leaving the upper part intact. If you notice, the doorskin is slightly different at the top in the area that I circled, this is why I would leave that area intact.... I figured once at that point, I could cut the new skin at the same spot and weld up everything as ebfabman does.... then just go ahead and crimp the doorskin on as originally done....
Just my ideas. Anyone else think of a way yet???
92 GMC K1500 Burb
Old 01-26-2004, 01:04 AM   #5
The Joker
3rd door
I have a couple or 3rd doors if you are interested.
The Joker
The Joker is offline   Reply With Quote
Old 01-26-2004, 04:41 AM   #6
junkyardjohn
junkyardjohn's Avatar
IT MIGHT WORK???? BUT IS WORTH THE EXPENSE & THE LABOUR?? I THINK i'D BUY A USED RUSTFREE ONE FOR $100 OR $150 THAT I KNOW WILL WORK FOR ME. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 01-26-2004, 06:08 PM   #7
bagged91
Out draggin'
bagged91's Avatar
I would LOVE to find one RUST FREE and straight for $100 to $150. The only problem is THEY AREN'T AROUND HERE!! I only know of 3 subs in my area and I own 2 of them. The other is a 51K orig mile 68 that is near mint.
I'm not in a hurry, if anyone on here is going to the spring Carlilse, Pa or Hershey,Pa swap meets in April and has a nice, rustfree door they want to sell me, I'lle pick it up then.
92 GMC K1500 Burb
Old 01-29-2004, 03:42 PM   #8
junkyardjohn
BAGGED91-- IF YOU WANT TO BUY A NICE , STRAIGHT, RUSTFREE 3RD DOOR, YOU PROBABLY WONT FIND ONE BACK THERE IN THE RUST BELT. MOST OF THEM HAVE EITHER RUSTED AWAY OR WERE CRUSHED 25 YEARS AGO. YOU WILL HAVE TO HAVE ONE SHIPPED FROM OUT WEST IN THE DESERT SOMEPLACE. AT A COST OF AROUND $50 -$60 FOR SHIPPING. JOHN
junkyardjohn
DON'T RENT U-HAUL
