#26 |
Re: Father/Son '58 GMC 4x4 Build
I saw in the 58 dump thread you wanted to know abt pitman arms . I used a dodge box in mine . Almost identical to a gm one . I had a second hole remed out with the same taper in abt 1 inch away from the orriginal hole Clears fine now I haven't even cut the end off of the pitman arm yet . It was reall y just the tie rod end that was hitting . there maay be a pic in the end of my thread . if not then i can get you some for sure
56 gmc 4X4 Cummins 5 spd 60F 70R 2005 Ram 3500 DRW cummins 4X4. 2006 Conolift 9/15. 2011 F 350 winter beater New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new ! My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908 |
#27 | |
"Built- not bought" 1958 GMC 150 4x4 in progress 1980 K20- Restored 1985 K3500 Flatbed 58 GMC 4x4 build thread: http://http://67-72chevytrucks.com/vboard/showthread.php?t=557675 |
#28 |
make sure you have a good strong eng hoist...... lol
#29 |
We have been making good progress over the past few weeks now that all the cutting and buffing is finally done. Assembly time!
#30 |
Decided that orange motor did not look right with the red truck...re-paint!
#31 |
Got everything re-wired in a couple days. Decided to splurge on Auto Meter gauges and billet dash. Figured I better make a pigtail for easy removal of the cluster.
#32 |
Raptor lined under all the fenders, inside bed/tailgate, floor pan, behind seat and steps. It's a great product.
#33 |
Man that truck sure looks nice . I wish I had the patience and skills to do body work like that . That was the big appeal to my truck . If I went with the old shop truck theme it didn't need paint . Keep up the good work. What wheel tire combo is going on it ? Did you get your steering worked out?
#34 | |
#35 |
color me impressed dyno
![]() nice progress in 2 years
cool, an ogre smiley Ogre's 58 Truk buildhow to put your truck year and build thread into your signature shop air compressor timer |
#36 |
Thanks Ogre...I struggled with the color as I have 2 other red trucks, but this baby was screaming for it.
#37 |
That is what I am shooting for, LineX on the cab floor and other places.. How much did it run you?
1971 GMC Sierra 1959 GMC 100 |
#38 |
It's called Raptor Liner, bought it at a local body shop supplier. I think it was about 130 for the kit, including the spray gun. Super easy to shoot and a really excellent product. I went thru 2 kits to do everything including under the fenders.
#39 |
Had a productive weekend. Got the motor fired up, no issues. Wife came running out with a big smile when she heard those open headers cackling.
#40 |
So, I got the stereo system in. I'm happy with the Retrosound Model two. A very tight fit with the wiper motor in the way, but I made it work. Built a box over the gas tank and put some nice 6x9 speakers in it. Also, got the E-brake pedal in place, thanks to Orrie's build.
#41 |
What a great looking truck and build thread!
Makes me want a red truck... hmmmm. How did you mount the gas pedal, any more pics or info to share? I have the same pedal but don't like where I mounted it.
Déjà vu. It's that feeling you get when you hit your thumb with the hammer a second time '59 Chevy 3100 Stepside |
#42 | |
Chopped 2" off the brake and clutch pedals, going to get them chromed.
#43 |
Recent progress; Got the seat and headliner in...very happy with them. Decided on a "Von Dutch" stitch on the seats for a little character. Got the steering shaft made...piece of cake (thanks Orrie). Also found a aluminum overflow tank for the remote brake master cylinder reservoir that worked out well. Actually drove the truck out of the shop for the first time and everything feels good. Time to put the doors together and finally get the front sheetmetal on.
#44 |
Like my remote res. WAY better than the cheesy plastic on that came in the kit. BTW, please excuse my firewall hole plugs. I sure wished I would have filled them, but at the time this was only going to be a d.d. Not anymore!
#45 | |
![]() ![]() I left a big loop of the braided cable between the firewall and the carb, otherwise I felt the jog the cable made from firewall to throttle lever was too tight and too short and the cable would grind against the housing - the big loop isn't much better as there is a lot of surface area but it's fairly smooth - at least I'm used to it now. I'll grab a pic this weekend. How did you land the throttle cable on the carb? BTW, love the upholstery and headliner!
#46 |
![]() Join Date: Jun 2010
The truck is coming along great...really looks nice!
1958 Chevy 1 ton dually 4X4 dump/flat bed My build thread 1966 "Not-So-Original" Chevy Custom Trim Suburban My Time-Killing Project Truck 1966 GMC Extended cab 1 1/4 ton 4X4 My Son's build thread |
#47 |
Thanks RT! Enjoying watching your build as well.
#48 |
Looking good, love the upholstrey.
#49 |
Thanks Orrie. Jim's over in Nampa did a nice job for me.
#50 |
Your upholstery guy Jim did a real nice job on the seat. Looks great.
Earl
You have to have patiences or you'll be one. |
| Bookmarks |
