door panels...
Do all door panels fit 67 - 72?
"Hey... its only time and money right? Just do it." 67 Short Bed under major construction http://67-72chevytrucks.com/vboard/s...=651356&page=8 |
Re: door panels...
Through '71. '72 molded door panel is thicker at the point where window crank passes through so the crank spline is longer on a '72.
Re: door panels...
So in the 67, what can I use that has the molded arm rests?
Re: door panels...
You should be able to use the the newer arm rests from a 70-71 with no problem. Only way to use a '72 would be to change the window regulator to a '72 setup.
Re: door panels...
Ok, I'll look into it... thanks
Re: door panels...
yes on plastic door panels the window regulators have longer stems
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
