Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 12-25-2014, 09:39 AM   #151
OLDYELLOW
OLDYELLOW's Avatar
Re: 70 Blazer Frame Off
Looks like your about ready to put the body back on the frame!
OLDYELLOW is offline   Reply With Quote
Old 12-25-2014, 12:27 PM   #152
IronCanine
I'm trying....
IronCanine's Avatar
Close...maybe by year's end even.
IronCanine is offline   Reply With Quote
Old 12-25-2014, 12:38 PM   #153
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Perfect!!!! Better than new in fact. Internally regulated alternator?
You probably are aware of this but be careful of the HEI when setting the tub back on the frame as clearance is real tight between it and the firewall.
Old 12-25-2014, 01:19 PM   #154
IronCanine
I'm trying....
IronCanine's Avatar
Thanks...yes, definitely internally regulated. Not planning on any big radios or anything, just A/C. Hope I'll be ok with the 63 amp.
We'll definitely be on guard with the firewall, but I went with the Pertronix "stock look" distributor, so I'm hoping my tolerances will be close to original.
Old 12-25-2014, 01:21 PM   #155
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I should look into that distributor - good idea. Did you use the aftermarket plug and play harness for an internally regulated alternator?
Old 12-25-2014, 01:22 PM   #156
IronCanine
I'm trying....
IronCanine's Avatar
Yep...that's the plan.
Old 12-25-2014, 11:18 PM   #157
1rippen6
It appears that the transfer case linkage that the shifter connects to is missing the pin. I think the linkage should have a pin at each end if I am not correct I am sure someone will chime in. I believe it should be silver soldered or some kind of brazing to hold it in.
1rippen6 is offline   Reply With Quote
Old 12-26-2014, 11:24 AM   #158
mx289
mx289's Avatar
Great build you have going here.
That chassis looks amazing !
Very good attention to detail.
Tom
71 K2500
71 K5 Jimmy
mx289 is offline   Reply With Quote
Old 12-26-2014, 10:08 PM   #159
IronCanine
I'm trying....
IronCanine's Avatar
It didn't seem unusual at tear down, I would welcome comments on this...Dwayne you're sending me scurrying through posts to see if my shift connection had been rigged up. My shifter connected to the linkage shown with a bolt/bushing/pin set up. The shifter is currently at the chromer.
Thanks.
Old 12-27-2014, 12:31 AM   #160
1rippen6
Thanks.
Sorry didn't mean to send you scurrying just I could be wrong but looked at the link below. I am thinking that is the way yours should look let me know what you find.
http://67-72chevytrucks.com/vboard/s...&highlight=nos
Old 12-27-2014, 01:14 AM   #161
IronCanine
I'm trying....
IronCanine's Avatar
Thanks for the pic (link) Dwayne.
...well it's getting late, I'm away from home and the truck for the holidays (so unfortunately, I can't just go look at what's hanging in a bag on the wall)...and I've searched and searched and searched for a clear pic on the site (I don't have a before pic of mine that shows my set up)...and the attached pic is all I came up with. Borrowed obviously from elsewhere on the board, it appears to show a bolt through the shifter. I guess mine could have broken or been drilled out, but it sure does seem clean. I'm anxious to get home and look at my hardware...but I think mine may have come with a bolt hole and not a pin. Again, experts weigh in for me. They had at least three transfer case shift levers in two different finishes that year, so it stands to reason they might have had more than one shift link...Thanks for looking and speaking up Dwayne. There's just too much stuff to keep up with on these trucks. It definitely takes a village to build one...
Old 12-27-2014, 12:00 PM   #162
DeadheadNM
Carpe manana
DeadheadNM's Avatar
The t-case shifter should just bolt into place with washer as shown - there is a plastic sleeve that fits over the bolt IIRC but these are typically lost to wear and time.
Old 12-27-2014, 12:10 PM   #163
1rippen6
I agree there is a bolt that holds the shifter on but what should the link look like between the handle and the shifter rod plate on the transfer case. Please see link below and then look at the picture on post 150. Just trying to make sure he has all the right parts to make it easier going back together.
Old 12-27-2014, 01:09 PM   #164
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Here's a pic from my K1500 - to my knowledge never removed by the original owner.
Old 12-27-2014, 04:40 PM   #165
IronCanine
I'm trying....
IronCanine's Avatar
I was talking about the lower bolt circled in red.
Thanks Pete...saw lots of these in search pics last night...as well as the twisted two pin style previously referenced by Dwayne. What I'm hopeful of, is that the attached pic is a factory correct variation and it's the same as what I've got. I'll sort it out and re-post pics when I get home. Thanks for the all the pics and insight.
Old 12-29-2014, 08:36 PM   #166
IronCanine
I'm trying....
IronCanine's Avatar
OK...I'm back home and got a few pics to post. First off, here's my TC shifter set up and I believe it to be a factory set-up. Instead of the two pin soldered set up as previously mentioned...and obviously different than later bent rod previously pictured...I've got a single soldered pin that goes to the transfer case side and then a loose pin through hole set up at the shifter side.
Old 12-29-2014, 08:43 PM   #167
IronCanine
I'm trying....
IronCanine's Avatar
Started putting some of the factory markings back in prelude to the reunion of tub and chassis.
Old 12-29-2014, 08:45 PM   #168
IronCanine
I'm trying....
IronCanine's Avatar
Picture pages, picture pages, lots of fun with picture pages, lots of fun with crayons and with pencils.
Old 12-29-2014, 08:48 PM   #169
IronCanine
I'm trying....
IronCanine's Avatar
Old 12-29-2014, 08:52 PM   #170
IronCanine
I'm trying....
IronCanine's Avatar
Copied member smbrouss70's St.Louis Blazer's trim markings since mine didn't have trim from the factory or obviously the corresponding marks. His was finished just a few weeks before mine...who knows the same guy might have penned both our trucks.
Old 12-29-2014, 08:55 PM   #171
IronCanine
I'm trying....
IronCanine's Avatar
...few more.
Old 12-29-2014, 09:03 PM   #172
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Nice - I see fresh paint! More pics!
Old 12-29-2014, 09:04 PM   #173
IronCanine
I'm trying....
IronCanine's Avatar
Even marked the back of the new cluster...had to post it...couldn't just hide it away. Tom (TBONE1964) may tell me I put it in the wrong spot for a tach dash...but it's just for fun after all. I even put Barbara's or Betty's or Bob's initial..or agent 13, whatever that mark on the lower left is supposed to be.
Edit: Sorry the red markings don't show up too well on the new cluster.
Old 12-29-2014, 09:07 PM   #174
IronCanine
I'm trying....
IronCanine's Avatar
Just the firewall. The plan is to put the tub back on tomorrow...so just having fun with grease pencils.
Old 12-29-2014, 09:12 PM   #175
IronCanine
I'm trying....
IronCanine's Avatar
This is a pic set I've been looking forward to forever...or at least since I saw member RackMan's beautiful rolling chassis...unfortunately, we're going to wait on the exhaust until the body is on.
1970, blazer, k5 blazer, restoration, silver
