#15 |
Re: IAC fried?
Many TBI trucks get a strange rhythmic misfire or stumble at idle when the fuel has ethanol in it. The higher the ethanol content, the more noticeable it is.
I you have poured anything in the gas tank, wait until you have a fresh tank of fuel before you get to involved in the idle misfire. If the system is retarding the timing just before the misfire happens, I would watch the knock counts and see if there is a considerable increase just before it retards the timing. If so, I can go into detail on the possible causes. If the timing retards happens just as, or just after the misfire, I would say the misfire caused it.
For those of you that are wondering why you are not getting replies to your thread: Did you give the model, year, engine, fuel system type, and transmission information? If it is modified from what came stock from the factory, let us know that too. |
| Bookmarks |
