Before and After
Sawzall
I am debating on getting a sawzall. Will they cut through rivets and frames?
Or are they just good for wood?
Not Grandpa's C-20 anymore... 383 Stroker 425HP, 485Ft/Lbs Lowered 3.5" Front / 5" Rear 66,000 miles. Alberta, CANADA |
Play it Loud...
With the right blade, they will cut through damn near anything
Big Moe =-=-=-= 1974 Cheyenne Super Stepside, 350/400, Hooker Headers, Flowmaster Mufflers... Needs new doors, fenders, hood, and paint. 1952 Chevy Pickup waiting to be brought back home! |
Use a grinder for rivets. Sawzall is good for sheetmetal. Plasma cutter or torch for frame, heavier metal.
at least this is my experience, scott
Silence is golden, duct tape is silver. - Scott |
Check out GMTrucks.org
With a metal cutting blade in a sawzall, you can use it to cut sheetmetal to frames. It is one of the most versitile tools I have.
Designated A-hole!
That's why it's called a SAWZ---ALL!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
I used mine to hack my dash to fit a new cd player cause I aint skeered:p
Buy good blades for cutting steel, the cheap one's are OK for thin metal. Rivets don't cut with blades. You could cut the steel easier than the rivets. Grinder and drills for rivets. The good one's have a quick change for blade for no tools needed. Mine has a setting that also drives the blade forward for aggressive wood cutting. I have a Porter Cable 737 Tiger saw...had it for few years..awesome tool.
64 Panel Rebuild Pics Clutch Replacement and Borg Warner T10 Trans Rebuild 64 Panel 1/2 Ton 350cubes/400hp BorgWarner t-10 3:73 Auburn Posi |
Watch out for your cornhole !
![]() Join Date: Jun 2003
I've cut anything with mine. Crossmembers, frames, rivets sheetmetal......
Dozens of Volkswagen bugs have fell victim to my SawzAll. You can cut one into small enough pieces to pile it in the bed of a pickup in about 10 minutes.
Keepin an eye out
I love my Sawzall along with my Visegrips
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
Got big-block?
![]() Join Date: Jul 2000
I c-notched the frame of my '93 with a sawzall.
Cut like butter. SC |
Lets ask you guessed it Bozall:p
Yeah they cut through just about anything ![]() ![]()
(Only) Member of the CPNE Fan Club ![]() ![]() 67 C-10 350 with 3-speed tranny and 308 gears swb step ![]() 82 Z28 Camaro 355 small block over 350 hp and a borg warner super t-10 (blown engine) 72 Chevy K20 Suburban (future project) 70 Chevy K20 now 68 GMC K2500 2003 Chevy 2500hd ccsb 4X4 (daily driver) |
