Old 12-31-2014, 02:00 AM   #1
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: JS LSX Turbo complete kits...anyone heard of this?
DEcide on the turbo, and I'll help you pick a wastegate. Too large of a WG can make it tough to control at low boost levels (this is also partially determined by how the overall amount of exhaust pressure we have to work with, a function of both the displacement, piping and turbo selection). Too small of a wastegate will increase the chance of creeping and spiking.
Essentially, you want the smallest gate possible that still eliminates creep. This is why some will choose to go with twin-smaller WG's in place of a massive dump. Its easier for the smaller diameter valves/springs to have "crisp" control over the boost levels.
As with all things turbo, its 50% thermodynamics, and 50% putting-the-lime-in-the-coconut and guesswork.
Most likely your looking at a 38-45mm gates. The 50+'s are probably going to be way excessive for your overall pressures and boost levels.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 01-02-2015, 03:50 PM   #2
Wasted Income
Boosted Member
Wasted Income's Avatar
First off, the guy in the video is annoying. The guy who said he sounds like a used car salesman nailed it. lol.
Originally Posted by BR3W CITY View Post
the 475 would be making over 450 at ~12-15psi,
That is on the low end. I helped tune a truck this summer that made 530hp/580 lb-ft at 10 psi with a 475 borg.
Depending on the turbo used, he might need as big of a gate as he can get. I had a Precision 46 on mine last year and it was creeping all the way to 15 psi with a 7 lb spring in the gate. I switched this year to a 60mm Turbosmart, and optimized the gate priority, and it still creeps to 10-11 psi with a 7 lb spring in it. With a large turbine and housing, there is just not enough backpressure to force exhaust out the WG. If i had a more restricive turbine, it would not be a problem to flow enough out the WG to maintain low boost. I don't really mind though, because 10 psi is as low as I'd ever want to go anyway
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 01-02-2015, 08:18 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
We're not special enough for variable geometry turbos yet
