camaro subframe
I am going to install a camaro subframe onto my 82 chevy shortbox. I can't be the first so does anyone have any advise (or pics) before I begin?
Re: camaro subframe
Why? The suspension is not that bad and can be made better with some simple mods.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
Re: camaro subframe
There have been a few show up in magazines over the years, but I've yet to see one get done by the average Joe and/or documented on the internet specifically for the squares. Seen a few 67-72's, but none in a square. I'd almost try to attach a 3rd gen bolt in aftermarket subframe to the stock frame rails, but I've done no measuring to even know if it's close or not...
- 1981 Sierra 454, NV4500 swap - 2006 Z06, 25k miles - 1973 Nova - Project CarNova Virus on Youtube |
Just here to tinker
![]() Join Date: Jun 2008
Re: camaro subframe
Sounds like a lot of work when there are so many aftermarket suspension parts for the trucks already; that are bolt on.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
I have no time for this
Re: camaro subframe
This is a waste of time there are lots of vendors to upgrade your truck with. But if you want a challenge then by all means go ahead knock your self out.
1986 Chevy short box ( PROJECT ) 1994 Chevy Blazer lifted 6" 2009 Gmc 2500 HD 1999 Hugger orange Camaro SS 2007 BMW X5 Sport |
#6 | |
Re: camaro subframe
So much negativity. Maybe he happens to have a parts Camaro.
Re: camaro subframe
Doing a subframe swap was the original plan for my project but I went in a different direction. I'm really interested to see some pics if you decide to move forward on it!
Re: camaro subframe
Here you go:
http://c10forum.com/forum/showthread.php?t=17672 I would still just make a few changes to the stock set up (move lower ball joint, taller upper ball joint, upgrade steering box or rack and pinion).
Re: camaro subframe
Well currantly my truck has been lowered 4" in the front (3" drop spindles and added 1" to lower spring pockets) and 7" out back (bought new spring saddles and made or modified the rest). This leaves approx 3" of travel before the tires contact the inner fenders. So the plan is to mock everything up and then install an 8.8 I.R.S. out back and install the camaro clip with stock height spindles up front, hoping to gain ground clearance at the front crossmember and/or lower control arm mount points. I hate seeing these from the front of the truck. I feel this will give me ample choices for brakes springs sway bars etc. I will take pics along the way if anyone is inerseted.
Re: camaro subframe
What is your goal here? If you keep the same ride height you will still only have 3" of travel before the tires contact the fenders. If your concern is ground clearance on the bottom side you could section your cross member 1". You could also go with a porterbuilt coil over setup and gain clearance.
Re: camaro subframe
My goal is to lower the truck 1" more. I know I could "Z" the frame but that has its own set of problems, I already have the subframe, I'll gain ground clearance, parts access and I like the work/challenge. To me a project is more than just bolting on parts. I'll always choose to build/fabricate something over buying parts. I guess I like the Custom part building something different or unique. I'll post a few picture soon.
#12 | |
Re: camaro subframe
![]() On the other hand...if you can make it happen and acheive what you are after...we'd like to see pics ![]()
my 86 c10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=496829 my 56 3100 build: http://67-72chevytrucks.com/vboard/s...09#post5712509 my 95 silverado build: http://67-72chevytrucks.com/vboard/s...35#post5879335 my gray 86 c10 http://67-72chevytrucks.com/vboard/s...34#post7624734 |
#13 | |
Re: camaro subframe
Re: camaro subframe
For the rear end do you plan on swapping in Exploder rear suspension or what?
1973 C20, 350/350 |
#15 |
Re: camaro subframe
I'll be using a independant rear suspension from a 1990 thunderbird super coupe.
I know that a kit is available and as is will lower the truck approx 5" from stock. I'm already down 7" but will be adding 1 more inch to achieve 8" even if I have to raise the bed floor. |
#16 |
Re: camaro subframe
Just my 2 cents worth...
I used a 73 camaro stub on my 52 A.D. truck ( I know.. way diff year) but for reference speaking. I did Z it 4" and using stock spindles and QA1 coilovers. This will give me all the travel I want/need and by Z'ing the frame as I want it will sit nice and low... check out my build I have posted pics on this at the early stages.. hope this helps.. Mark...
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
