Old 01-01-2015, 11:12 PM   #751
MAC71
MAC71's Avatar
Re: 69 GMC "Ol' Blue"
I built a clutch linkage with rod ends like yours for my vette years ago. Makes the clutch really smooth.
Your truck is looking really good. Lots of thought is going into it and some cool mods!
Mike
1971 C10 350
1969 C20 396
1979 Corvette L-82
MAC71 is offline   Reply With Quote
Old 01-01-2015, 11:15 PM   #752
mjensen
mjensen's Avatar
Thanks Mike! I am having a lot of fitment issues due to the engine move, but it's moving. I really need to get the 4wd lever and wiring figured out.
Mike
'69 GMC 3/4 ton 4x4 Build Thread
mjensen is offline   Reply With Quote
Old 01-01-2015, 11:19 PM   #753
mud.man.rj
mud.man.rj's Avatar
Headers fit quite well, have seen way worse myself. Coming along nicely, lots of small picky stuff hey.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 01-01-2015, 11:44 PM   #754
mjensen
mjensen's Avatar
Thanks mud man! Yeah, I'm glad they worked out with minimal mods
Mike
Old 01-02-2015, 01:18 PM   #755
americanmusc1e
americanmusc1e's Avatar
Looking great mike!! You just need to get it running and then you will really want to get it finished!
I found out that my 8 year old flowtechs have a giant hole where the four pipes join the collector. I was considering the same headman headers that you have, but since the flowtechs fit so well, I may go with them again. The thing i hate about the flowtechs is they have really cheap header flanges and I end up having to use aluminum gaskets to get them to seal off.
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
Old 01-02-2015, 07:14 PM   #756
mjensen
mjensen's Avatar
Thanks! I think if I get the wiring figured out, I will be real close to firing her up!
I'm not sure how well these headers will hold up, but what do you do
Mike
Old 01-02-2015, 07:15 PM   #757
mjensen
mjensen's Avatar
Today I finally worked on my rear brake lines. I now have them bent, but not completely tied down.
Mike
Old 01-02-2015, 07:56 PM   #758
americanmusc1e
None of them are going to last forever. The thicker gauge tubing helps. Mine have already been rewelded about 3 times
-- Josh
Old 01-03-2015, 10:10 AM   #759
rgunlock
rgunlock's Avatar
The brake line looks good Mike - one more step done. I'm counting on you to get all the wiring figured out so that you can answer my questions when the time comes!
Rick
78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel
71 GMC C25 350/TH400 - Project Angie
59 Chevy SWB Stepside (next in line? Not sure now )
2001 GMC Sierra K2500
rgunlock is offline   Reply With Quote
Old 01-03-2015, 12:12 PM   #760
mjensen
mjensen's Avatar
I am really nervous about having sealing issues on the driver's side. It is just real tight, and there will be some tweaking to get the exhaust to clear the bellhousing. I guess I'll find out when I fire it up for the first time
Thanks Rick! Yes, one more item to tick off! As far as the wiring is concerned, I had to walk away for a bit . The engine side is pretty simple, as there really aren't too many sensors and gadgets on the '91. The inside is a different story. Being the donor was a blazer with power everything, and I'm putting it in a truck with power nothing I'm really struggling with the best way to start removing unnecessary wires. I think I just need to close my eyes and start cutting. Not really, just need to stop whining and get going.
Mike
Old 01-03-2015, 04:49 PM   #761
7dee2
7dee2's Avatar
Man you on a roll now! Should sound great with the headers. Any luck with the 4x linkage yet?
Brett
67 Camaro SS: 67 Camaro Build
72 Cheyenne/C10 Super 115" Fleetside: 72 C10 Build
72 Cheyenne/K30 Super 133" Longhorn DRW: 72 K30 Build SOLD
YouTube: https://www.youtube.com/@6dee7-7dee2
7dee2 is offline   Reply With Quote
Old 01-03-2015, 05:12 PM   #762
Jahloha
Jahloha's Avatar
Hell yeah! Good job Mike, things are looking awesome.
You are really killing it, keep inspiring me haha
-JASON
My grandpa, Gramps, won a 1970 C20 in 1969 for $1. I'm on a mission to restore it before he passes.
My 1970 C20 Build Thread
Jahloha is offline   Reply With Quote
Old 01-04-2015, 12:37 PM   #763
mjensen
mjensen's Avatar
Thanks Brett! The neighbors are going to know when I get it fired up for sure! I'm still struggling with the 4x, but I think I have a plan for the clutch.
Thanks Jason!
Mike
Old 01-04-2015, 12:46 PM   #764
mjensen
mjensen's Avatar
Yesterday, I started mocking up my idea of where I want the clutch linkage to go. I think this will work, but just in case, I'm using the cheap scrap tubing instead of the chromoly stuff that I will finalize the design with.
In this first pick, if you look through the hole below the steering column, you can see the top of the Z-bar. For this to work, I'm going to have to extend the bar up a bit.
Mike
Old 01-04-2015, 09:47 PM   #765
mjensen
mjensen's Avatar
Ok, if anyone sees an issue with my clutch linkage setup, please let me know!
Mike
Old 01-05-2015, 01:40 AM   #766
MAC71
MAC71's Avatar
Making progress. So when do you think its going to get fired up? I would like to be there for that if I can?
Mike
1971 C10 350
1969 C20 396
1979 Corvette L-82
Old 01-05-2015, 01:30 PM   #767
7dee2
7dee2's Avatar
Not seeing a problem as long as it doesn't bind and you have full motion and can adjust the bar lengths for optimal pedal/throw out bearing adjustments I'm thinking it's good to go!
Edit: Make as much room as possible between the brake and clutch pedal arms. It would suck to get something stuck in there at the wrong time.
Brett
Old 01-05-2015, 10:36 PM   #768
ryanroo
ryanroo's Avatar
i would be sure to gusset or support your stand off on the pedal arm itself. if you rely on the tension in the bolt alone to hold it all i think it will begin to wiggle and wallow.
how is the z-bar pivot on the frame held in? it looks loose
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 01-05-2015, 10:41 PM   #769
americanmusc1e
That looks nicer than my hydraulic setup
-- Josh
Old 01-05-2015, 11:32 PM   #770
mjensen
mjensen's Avatar
I need to figure out my wiring mess first. I'm hoping to try and get it to a fire point by the end of February. That would be awesome to have you come check it out!
It has no binding right now. In this configuration, I can't put the metal ring back on that holds the rubber grommet in, but I think I can make something work. I am going to continue to mess around with it to see if there is a way to gain a bit more clearance.
My plan was to purchase some metal spacers with a 3/8" ID and 3/4" OD that I can weld to the clutch pedal to help with that. Do you think that would work, or should I try something else?
It's held on exactly the way it was in its stock form, but I may not have had it tightened down when I took the picture.
Thanks!!!! I think it's turning out ok, just a bit more tweaking and I think it will be rocking!
Mike
Old 01-17-2015, 02:08 PM   #771
Mustard72
Mustard72's Avatar
That clutch linkage looks great, Mike. It'll be one of those things you will feel bad about covering up with such frivalities as the cab and stuff...
Nick
Old Mustard, 1972 Chevy C20, 350, TH350, 4.10 Dana 60 rear, owned since I was 16 in 1986
http://67-72chevytrucks.com/vboard/s...d.php?t=545356
Blue Bell, 1987 K20, 6.2L Diesel, TH400/NP208, 4.10 gears
Ustahav 1976 K10, 350/350/203, Gov Loc, Yooper beater trail truck.
Mustard72 is offline   Reply With Quote
Old 01-17-2015, 10:37 PM   #772
mjensen
mjensen's Avatar
Haha...Thanks! Yeah, now if I can just figure out the 4wd lever, I'll be in good shape
Mike
Old 01-18-2015, 01:43 PM   #773
mjensen
mjensen's Avatar
So, I've been out of town all week and don't have any new progress to report. I did realize that I never posted pictures of my latest mockup for the 4wd lever. I do have a lot of snaking and moving around to do here, but I think this will end up working out. I will have some items to address with the floorboard, but hey...we'll figure it out
See how high the pivot point ends up having to be though. I am not sure I like that idea, but honestly I'm not sure if I have a choice.
Nothing is set in stone here, so if someone has a better idea, I'm all ears. After sitting here staring at the picture, maybe it would be best to go back to the original mounting location and see if I could tweak the shifter to keep it out of the seat.
Mike
Old 01-18-2015, 03:30 PM   #774
mud.man.rj
mud.man.rj's Avatar
Looks confusing with all those shifters, if left alone only you can drive it,,
5.0 4spd std.
7" lift w 35's.
Old 01-18-2015, 03:51 PM   #775
mjensen
mjensen's Avatar
Haha...well that is the plan lol. My daughter keeps telling me that it will be her truck when she turns 16. If I make it too confusing to drive, I think I'll be safe getting her something else
Mike
