Old 12-31-2014, 03:34 PM   #126
ls1nova71
ls1nova71's Avatar
Re: Help with fuel system design for LS1 install
Originally Posted by Badcompany21 View Post
im swapping a 03 5.3 with return style lines in my 64 is anyone using a inline pump and the factory in the cab tank? If so how did you run the return line into the tank
thanks
I've done it a couple different ways. There are links to my build threads in my sig, and there are pics of both ways I've done it. I like the sumped tank the best.
Does Kanasa City mean Kansas City?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 01-01-2015, 11:04 PM   #127
Badcompany21
Yes lol
Badcompany21 is offline   Reply With Quote
Old 01-02-2015, 01:38 PM   #128
twp1
LS1 Camaro fuel filter. Do you have a part #?
twp1 is offline   Reply With Quote
Old 01-02-2015, 03:53 PM   #129
brossow
Amateur Rust Fighter
brossow's Avatar
The LS1 Camaros use an in-tank pump with its own attached filter, AFAIK. Why would you want this? If you're looking for the part number for the LSx Corvette external filter/regulator, see the very first post in this thread.
Brent
'72 Chevy SWB stepside - [ Build Thread ]
'79 ChevMC SWB fleetside - [ Build Thread ]
'64 Chevy SWB fleetside & '66 Chevy SWB stepside (waiting in the wings...)
brossow is offline   Reply With Quote
Old 01-02-2015, 03:56 PM   #130
twp1
I thought I read in one of the past threads that if you had a return line off the fuel rail I needed to us Camaro one instead? might be reading it wrong.
Old 01-15-2015, 11:50 AM   #131
Marty68
ls1nova71 what is the basic dimensions of your sump you built on your stock tank? did you mig weld it? would silver solder be an acceptable manner to attach sump to tank?
Marty68 is offline   Reply With Quote
Old 01-15-2015, 09:23 PM   #132
six two swb
i would suggest s.u.r.& r.kit comes with everthing to do a complet fuel fix from in tank to fuel rails part# kp1500 deluxe kit best price was from national tool that i could find they also have brake kits an trans kits a snap.
six two swb is offline   Reply With Quote
Old 05-22-2017, 10:43 AM   #133
matt_l
Based on all the reading here, here is the plan I came up with to route fuel from a Boyd tank with intank fuel pump. Did I miss anything? Is 25 feet enough or too much? Fuel tank is mounted under the bed.
Matt
Father Son 66 Build: http://67-72chevytrucks.com/vboard/s...d.php?t=564694
matt_l is offline   Reply With Quote
Old 05-22-2017, 01:22 PM   #134
yossarian19
Depends which rails you have, return style or returnless. If you have returnless rails that will do it but I would look at using OEM type nylon fuel line & connectors to save a boat load of money over going all AN stuff.
"Over my head"
1957 Chevy 3200, big rear window & 6 lug.
Front disc, power steering, Vortec 4.8 / 4L60E swap, hydro boost brakes & patina.
yossarian19 is offline   Reply With Quote
Old 05-22-2017, 04:44 PM   #135
matt_l
Thanks for the response, that is a great idea. Mine is a return-less, and I did a little digging. Unfortunately I could not find a -6orb to 3/8 SAE Quick disconnect, so I had to use a combination of connectors coming out of the pump. Even with that, this is a significant savings.
Matt
Old 05-23-2017, 03:48 PM   #136
67ChevNut
Very interesting thread, following.
Like your system BR3W City, you think you have part numbers for some of those fittings, and stuff you used?
67ChevNut is offline   Reply With Quote
