Closed Thread
Old 01-02-2015, 12:31 PM   #1526
VWNate1
VWNate1's Avatar
Exclamation HEI Upgrade
Originally Posted by CST10 View Post
Converted my ol 68 C10 inline 6 cylinder from points ignition to an HEI set up. It runs so much smoother and better now. Finally got rid of that stumbling issue that popped up every now and then.
Don't forget to open the spark plug gaps up to at least .045" (I'm running .070") and enjoy the extra power ! .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 01-02-2015, 02:40 PM   #1527
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Re: What did you do to your truck today? Chapter II
Its +1F or -17C outside and snowing in the Great White (cold) North and I'm at work today so all I can do is dream about all the things I am going to do to my new truck when it starts to get nice here in April...
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Already Gone is offline
Old 01-02-2015, 04:30 PM   #1528
CST10
CST10's Avatar
Re: HEI Upgrade
I set them at .060". Runs like a champ now.
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline
Old 01-03-2015, 05:26 PM   #1529
UNEASYRIDER
UNEASYRIDER's Avatar
Fixed a rip on my seat!
DON'T BUILD IT IF YOUR NOT GONA DRIVE IT!!
UNEASYRIDER is offline
Old 01-03-2015, 06:33 PM   #1530
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
I taught myself that I have not learned a damned thing about building these trucks in all my 68 years.
On my way to take care of the chickens this morning ("Yes, dear." "I'm glad you want to have eight chickens just like your old Italian neighbor
did when you were a kid." "I'm sure that you *will* do all the work."), I passed RAT siting and waiting for the rest of the stuff that's coming
(white face overlays) in order to install a slick amp:volt gauge kit from Forum Member, Forum Merchant, and all around good guy Tom at:
http://www.classicgaugeandcluster.com/
I remembered that I'd been head-scratching over the dash lights going dark a couple of months after installing the LCDs. Since I don't drive
much in the dark, I'd forgotten that I need to address that. And, since I want to pull the dash and bezel to install the kit from Tom, and I'd
already checked the fuse block on the chance that...well you know...fuses.
So, off with the dash grommet retainer, parking brake assy., undo the screws, push the light switch button under the dash to pull the "switch mast",
unscrew the ww and faux choke knobs, unbolt the under-dash steering column yoke, unscrew the phillips that hold the bezel on....clip the lines to
the non-GM tach. Unbolted the oil pressure gauge line, and the speedo cable.
Replaced a bulb that was burned out (one of the orig. that I couldn't reach when I installed the LCDs).
No dash lights (juice is there at the connector, 'cause the turn signals, etc. work). Brand new M&H harness. Pretty.
Got on the ground with a flashlight and peered at the fuses again. Pulled the 3A cluster fuse. Looked good. "WAIT!!!" "LOOK!!" "Hold it up to the light!"
"It's ever so slightly blown." Which means, it's blown.
Glad I waited to multi task to pull the dash, (the amp gauge:volt gauge conversion from Tom), or I'd really be pissed at myself.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 01-03-2015, 07:17 PM   #1531
Possmguts
Possmguts's Avatar
gazed at and adjusted my Shopping cart and though about how I wish i could hit the checkout button...
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline
Old 01-03-2015, 07:28 PM   #1532
outdoorsman310
outdoorsman310's Avatar
Moved my toolbox up the highway with the failing transmission thm350. Was ok until i was parking it. What you can't see is my other truck loaded with my toolboxes, cart, and vortec 350 for the '70.
Putting a sm465 and vortec engine in it.
outdoorsman310 is offline
Old 01-03-2015, 08:45 PM   #1533
67CC
Pulled engine out a few months ago. Freshened it up, new cam, heads, and valve gear. All this took a lot longer than planned and I had a lot of trouble getting it going.
So today I went out in the snow and played around with getting the dizzy in right(that was another thread) and it finally fired up! Yessssss! Just in time to let it sit all winter, though. Haven't got to drive it yet. Well, we'll see.
'67 C20 Custom Camper. 327, three-on-the-tree. No power anything!
67CC is offline
Old 01-03-2015, 09:43 PM   #1534
Crazyduck
Started putting this together.
Crazyduck is offline
Old 01-04-2015, 12:58 AM   #1535
notsomellowyellow
notsomellowyellow's Avatar
Spent my birthday at the shop putting my 70 back together. After staying at the body shop until 11:45pm on new years eve(yes my wife has disowned me) I needed to take a couple days out and get back on track. Far as I got today, was putting the new Weld Draglites and BFG'S on and installing the grill.
notsomellowyellow is offline
Old 01-04-2015, 08:55 AM   #1536
BugzC10
BugzC10's Avatar
Nice looking rig ....more pictures and specs please.
And welcome aboard.
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline
Old 01-04-2015, 10:30 AM   #1537
DaHos
DaHos's Avatar
Got the floor cleaned and coated, then I got the 350 "mouse motor" out to get it ready for mockup..........had a little eviction party.....
1967 C10 SWB
Owner - Rustbelt Restorations
DaHos is offline
Old 01-04-2015, 10:53 AM   #1538
88fordf150
88fordf150's Avatar
What did you coat the floor with? I'm trying decide between paint or coating. Where a bouts in Michigan are you from? I'm in Jackson County.
Brad handshoe
88fordf150 is offline
Old 01-04-2015, 11:10 AM   #1539
DaHos
DaHos's Avatar
Dupli-Color Truck bed liner in spray can..........I'm up in Owosso.......
1967 C10 SWB
DaHos is offline
Old 01-04-2015, 11:19 AM   #1540
Boog
laying low
Boog's Avatar
Mouse motor indeed. Those little buggers will nest up anywhere.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Boog is offline
Old 01-04-2015, 05:42 PM   #1541
notsomellowyellow
And welcome aboard.
Thanks for the welcome. The truck is a 1970 Fleet, running 550hp, GM 502, Turbo 400, 2500 Stall, mini tubbed, 12Bolt 3:73 Moser Axles, MSD, 345/55R15 BFG Drag Radials, 3" Flowmaster Exhaust. Body has 4" Chop, frenched and shaved everywhere and has just been painted Spa Yellow(Acura NXR colour) with water born Dupont Cromax Pro paint. It still needs a interior update, as the truck was originally customized in the 90's, so thats next winters project.
GM 502, 4L80E spd auto, Compushift II, 2500 Stall, mini tubbed, 12Bolt 3:73 Moser Axles, MSD, 345/55R15 BFG Drag Radials, 3" Flowmaster Exhaust. 4" Chop, frenched and shaved everywhere, custom Pearl Yellow paint.
Old 01-04-2015, 06:23 PM   #1542
Already Gone
I like those valve covers, are they from a Corvette? Are they available from a vendor?
Old 01-04-2015, 06:23 PM   #1543
ole dollor
ole dollor's Avatar
well happy birthday and welcome to the forum from Texas .that is a real nice truck you have there....
ole dollor is offline
Old 01-04-2015, 06:28 PM   #1544
Crazyduck
Yea they are from a vette... Although I bought the engine used with them installed so not sure where to get a set. Glad you like them I think they are pretty sweet.
Old 01-04-2015, 06:36 PM   #1545
Possmguts
Possmguts's Avatar
WOW.. how did those buggers get in there?
Old 01-04-2015, 06:50 PM   #1546
Ozzy2013
Ozzy2013's Avatar
Your so right been there done that too sometimes i guess we just forget to check the simple things first .ha ha
Ozzy2013 is offline
Old 01-05-2015, 05:18 PM   #1547
Lou Boffa
Lou Boffa's Avatar
Nothing fun, but sure needed to be done: Upper/Lower Arm shaft/bushings, upper/lower ball joints (and a brake line I broke...DOH!) No more shimmy--nice tight ride.
Figure out what you want--then figure out what you are willing to give up to get it.
Lou Boffa is offline
Old 01-05-2015, 07:06 PM   #1548
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Got my NOS tailgate hinges powder coated...
DeadheadNM is offline
Old 01-05-2015, 07:28 PM   #1549
smsdm02
I put the first 50 miles on the rebuilt 350 and drove it for the first time in 13 months!
smsdm02 is offline
Old 01-05-2015, 11:03 PM   #1550
Devins-step
Finally got the brake lights, tail lights and signal lights to work!!! I HATE electrical problems.
Devins-step is offline
Closed Thread
