![]() Join Date: Dec 2014
Re: New guy, goin' in dry
Thanks guys! killthewabbit, I just picked-up a fitting at AutoZone ($6.99 P/N-098806 *HELP#56360), same as used on the old small block Chevys. 1/2" male pipe thread 3/4" heater hose size on the other.
OK, went in and fired-up the truck this AM, could tell it was running a bit rough. Shut it down, and double-checked distributor...sure enough, I smooched the pooch and had it 1 tooth off. SO, reset it and runs like a champ! Changed oil/filter, serpentine belt, added a mount and lamp for license plate on that fugly farm bumper to at least get me legal. Took it for a 10 mile spin, and visibly checked for leaks, so far so good. Thought I might tackle the exhaust leak at the converter flange under the right rear side of the cab(behind trans mount cross member and frame cross member about 18" aft. The gasket I have is the wrong one anyway, and I saw someone had broken 1 of the 3 bolts off the flange, so I decided I'll probably just take it to a muffler shop and let them fool with it. There's a bolt the flange on each side of the 2 pipes, just couldn't get them in the pic. AZ didn't even have a listing for it, and ORileys wasn't the right gasket. Anyone have any ideas, or had to replace this gasket? ![]() Be nice not having to worry about a coolant leak. I'm wondering if that's not the reason the PO sold it. He'd just replaced the water pump, maybe he thought it was the source of the leak?
"The problem with quotes on the Internet is that it is hard to verify their authenticity." Abraham Lincoln |
| Bookmarks |
