Old 01-01-2015, 08:37 PM   #1
nbrfd007
nbrfd007's Avatar
1985 4x4 Crate Engine Swap old school 350 or Vortec 350
Need to put an engine in my 84 4x4, 305 at this time. Thinking of ordering a GM crate engine. Would it be better to put a carbureted Vortec in it or go back with a regular 350? Much problems with the updated Vortec motor swap?
Thanks,
nbrfd007 is offline   Reply With Quote
Old 01-02-2015, 01:23 AM   #2
Ziegelsteinfaust
Re: 1985 4x4 Crate Engine Swap old school 350 or Vortec 350
Go vortec more torque under the curve, and a roller cam. Which is suitable for today's zinc free oils.
I want one for my 4x4 build with full bolt-ons, and maybe a slightly bigger cam. I fantasize about a turbo, but it would likely kill parts.
Ziegelsteinfaust is offline   Reply With Quote
Old 01-02-2015, 03:14 AM   #3
slug
slug's Avatar
For a vortec You will most likely need a electric fuel pump and a regulator with a return line. Everythin else should bolt right up with the exception of the intake.
there is nothing better than cutting metal with fire.......except cutting metal with electricity!!!
slug is offline   Reply With Quote
Old 01-02-2015, 05:02 AM   #4
cfan10
cfan10's Avatar
Vortex without a doubt...thinking of doing a 5.7 in my 10 cheap and easy to come by, junkyards are full of them. Really want a 5.3 but with my budget right now...
Rest In Peace:Mikhail {Mickey Rooney} Alpha 2/5/13 Omega 7/22/14 10:28AM I love you tremendously and outragiously Superpuppi Thai Ridgeback...The most intelligent dog known to me.
Don't mess with my truck, my momma or my money...not necessarily in that order. ©
Stand for something or fall for anything.
[LIST][*]'98 Bourbon St. Brawl ©2010
cfan10 is offline   Reply With Quote
Old 01-02-2015, 10:39 AM   #5
naphtali5725
naphtali5725's Avatar
why not have a custom engine built… can get one just as cheap or cheaper than a vortex or standard chevy crate motor from GM… better components, stronger, will last longer etc. thats's what i would do, (it's what I did) use the savings for something else for your truck
My build thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=515829
Disabled Veteran
82nd Airborne Division
Operations: Desert Shield, Desert Storm, and Uphold Democracy
naphtali5725 is offline   Reply With Quote
Old 01-02-2015, 06:33 PM   #6
Jake Wade
Jake Wade's Avatar
Please fellas, its Vortec.
Jake Wade is offline   Reply With Quote
Old 01-02-2015, 06:35 PM   #7
naphtali5725
blah, ok Vortec… still would be cheaper to have a custom engine built...
My build thread...
Disabled Veteran
Old 01-02-2015, 10:40 PM   #8
wideopen1967
wideopen1967's Avatar
I'm building a small block 400 with Vortec heads. Similar to these,
http://www.hotrod.com/how-to/engine/...k-chevy-build/
http://www.hotrod.com/how-to/engine/...-block-engine/
http://www.hotrod.com/events/coverag...c-small-block/
wideopen1967 is offline   Reply With Quote
Old 01-02-2015, 11:57 PM   #9
rich weyand
rich weyand's Avatar
I went with the base 350 crate and cammed it for torque. No other changes.
New engine, lots of torque, cheap.
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
Old 01-03-2015, 09:19 AM   #10
cadillac_al
Doesn't GM make a 383 Vortec? If money was no object that should be a consideration.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is online now   Reply With Quote
Old 01-03-2015, 09:43 AM   #11
Desert1957
Desert1957's Avatar
Just curious to everyone who says build an engine is cheaper then a crate motor.If your talking rings and bearings, new gaskets, and hand lapping the valves which is basically a garage freshen up, maybe its cheaper.
IMO if you price up all the parts and the "proper" machine work, its not cheaper.
Anyone who can show me a machine shop that will do all the machine work cheaper I would love to start using them.
All my engine blocks get this labor.(350 Priced)
1. hot tank block
2. mag block for cracks
3. deck block (if needed)
4. .030 bore on cylinders
5. line bore
6. clean all oil galleys
7. cam bearings installed
This is ONLY the block labor, not including cylinder heads overhauled, or any parts. usually come out to about 55% of a new crate motor.
Is it a better engine then a crate motor?, of course, but cheaper? I don't think so.
Desert
Desert1957 is offline   Reply With Quote
Old 01-03-2015, 10:02 AM   #12
naphtali5725
1. hot tank block
5. line bore
Desert
I guess we should ask him what his budget is...
Desert, what did you pay ?
I had a 500hp/500tq Pontiac 461 built with all new parts.. eagle rotating assembly, balanced, custom forged pistons, hyd roller, all machine work as you listed, new valves/springs/locks/keepers, comp valve job, heads mag'd etc. etc. etc. no used anything...
5800.00
Oldsmobile 461, same type components and all machine work as the Pontiac… 4500.00
Parts for Olds/Pontiac are way more expensive than SBC parts...
so i know for sure I could have a small block chevy engine built with lots o power, for as cheap as an out of the box new motor from scoggins dickey…
Unless he just wants a completely stock 200hp motor...
just have to check around, plenty of options out there..cheaply on the money side, not the workmanship
if you want the shop names, let me know both have won national drag championships… my Pontiac builder, built the engine for the fastest Pontiac.. the dirty bird
My build thread...
Disabled Veteran
Old 01-03-2015, 09:36 PM   #13
rich weyand
Base 350 with torquer cam: under $1700 for 285 hp, 420+ lbft.
Rich Weyand
1978 K10 RCSB DD.
Old 01-03-2015, 09:55 PM   #14
nbrfd007
nbrfd007's Avatar
Trying to keep it under $2000.00. Most rebuilding prices I have found $1500.00 to $1650.00 with my core.
Old 01-03-2015, 11:03 PM   #15
nbrfd007
nbrfd007's Avatar
What brand of Crate Motor?
Old 01-03-2015, 11:05 PM   #16
naphtali5725
yeah, with a low budget like that, not much can be done except a good solid stock type + a good cam like rich said… but there's always nitrous lol
My build thread...
Disabled Veteran
Old 01-04-2015, 09:16 AM   #17
Jake Wade
Jake Wade's Avatar
This one:
http://www.jegs.com/i/Chevrolet-Perf...oductId=752506
Old 01-04-2015, 09:24 AM   #18
80SPORT
80SPORT's Avatar
The GM crate motors are great value;all new parts and a GM warrantee.We do not rebuild motors anymore except custom applications or matching numbers originals.
80SPORT is offline   Reply With Quote
Old 01-04-2015, 11:42 AM   #19
cadillac_al
For another $500 you can get a 4 bolt 1 piece rear seal and roller cam and vortec heads.
http://www.jegs.com/i/Chevrolet+Perf...30283/10002/-1
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
Old 01-04-2015, 11:52 AM   #20
naphtali5725
the roller cam is worth the 400 alone… much less the 1 piece and vortec heads...
My build thread...
Disabled Veteran
Old 01-04-2015, 11:52 AM   #21
Jake Wade
Jake Wade's Avatar
That is the one I would want, roller cam, Vortec heads, 1pc rear seal.
The engine I posted for him is a direct drop in with the least expense.
With the Vortec crate, a different flexplate/flywheel is needed, different intake manifold, throttle cable braket will need to be modified or a different one purchased and an electric fuel pump will be needed as this block does not have provision for mechanical fuel pump.
Old 01-04-2015, 12:01 PM   #22
naphtali5725
yes, those extra mods/expense may or may not be worth it… but a roller short block would be a cheap way to go as well
My build thread...
Disabled Veteran
Old 01-04-2015, 12:24 PM   #23
enaberif
Everyone is forgetting to go to a vortec engine is going to be more than just an engine. You will need a lot of extra stuff, a bunch of time, and a whole lot of patience.
There is a reason why crate motors exist for our trucks.. to simply keep costs down and keep it simple.
enaberif is offline   Reply With Quote
Old 01-04-2015, 02:55 PM   #24
jeff mcleod
jeff mcleod's Avatar
I am going though the same thing myself. I planned on rebuilding the 350 cu.in 4 bolt. I tore it apart to find out the block was cracked on #8 hole in the valley . the best part it had 305 heads on it.
For me to build a 350 4 bolt at the local engine shop I will have well over $ 1500.00 tied up.
I plan on going with a GM grate from local GM dealer.It will be the 290 horse 4 bolt as the block I had was a 2 piece rear seal so I dont have to change my flywheel.
With going crate you have a milage and year warranty to boot.
jeff mcleod is offline   Reply With Quote
Old 01-04-2015, 03:36 PM   #25
rich weyand
Do NOT go with the 350/290hp GM crate engine. All it is (for an extra $500) is the 350/260hp crate engine with the cam out of a 1967 Corvette 350/350hp high-compression engine. In particular, it has high overlap that reduces dynamic compression at low rpms, which, with a high-compression engine, you can afford to give up and it allows more advance because the low dynamic compression at low rpms will reduce the tendency to knock.
What a cam like that means on a low-compression engine is that you will have no bottom end at all. It will completely suck in a truck until you get 3000 rpms under it. It is also a very old cam design, without the high-speed ramps and computerized design of modern products. Also, the fuel mileage will completely suck. We're talking mid-single-digits here.
On the other hand, it will be a two-lane terror with a really nice 50-90 time with your foot in it.
I went this route myself, and ended up recamming the motor. Since the only difference between the 350/260hp and 350/290hp crate engines is the cam, I could have saved the extra $500 (and the expense of changing out the cam), and just gone with the 350/260hp crate engine and recammed it from the get go.
After all of this, my recommendation for a cheap performer is the #10067353 350/260hp crate engine, with a Comp Cams 12-235-2 cam. That's the cam Sean Murphy over at SMI recommended to me a couple years back, and several people have gone with it and liked it. With headers and a dual-plane manifold, you'll see 290hp @4000 and 415lbft @2500, which is a really nice torque number down low where you want it. You should upgrade the springs with this cam, but that's it. If you put it in a never-run 350 crate engine, you don't even need to change out the lifters.
I went with the Comp Cams 12-300-4 cam, which gives 275hp @4000 and 423 lbft @2500. No spring change required, but I did lower the shift points 500 rpm at WOT by changing out one weight on the transmission governor, which is a half-hour job.
But if you go with the 350/290hp crate engine, you will be disappointed. Been there, done that.
Rich Weyand
1978 K10 RCSB DD.
