Old 10-25-2014, 12:06 PM   #1
Geri
Rebuild kit for a 1953 3-Speed Transmission
Hello everybody,
i,m looking for a rebuld kit for my 1953 Chevy Truck 3-speed transmission.
Does anyone know, where i can get these parts? Dealer, Store etc.
Thanks Geri
Geri is offline   Reply With Quote
Old 10-25-2014, 12:47 PM   #2
Old Truck Man
Old Truck Man's Avatar
Re: Rebuild kit for a 1953 3-Speed Transmission
That old 53 trans has bushings instead of roller bearings on the mainshaft. However you can install the guts from a 55 thru 64 Muncie 3 speed in your trans case. Ive did it many decades ago. I don't remember just what parts I used on the outpuit shaft to retain the closed drive line.
Old Truck Man is offline   Reply With Quote
Old 10-25-2014, 01:48 PM   #3
dwcsr
Hollister Road Co.
dwcsr's Avatar
http://transpartswarehouse.com/index...1940-1950.html
Kit number is BK131
Old 10-25-2014, 01:55 PM   #4
mr48chev
mr48chev's Avatar
He's in Germany folks so he can't run out to Napa and pick up parts.
Geri as far as ball bearings go you should be able to find those locally if you take the old bearings into the local parts store or bearing store. There is no need for you to pay the high shipping costs on ball bearings that may have come from Germany originally anyhow.
From the Classic parts website. The gasket set
http://www.classicpartsusa.com/produ..._Parts_Gaskets
Some pieces here https://www.chevsofthe40s.com/dept/T...+Bushings.html
This outfit has gears and synchronizes and small parts kits.
They also have gaskets.
http://www.vapinc.com/chevy/Transmis...arts/main.html
My ongoing truck projects:
Old 10-25-2014, 01:57 PM   #5
mr48chev
mr48chev's Avatar
The kit that Dave showed in post #3 while I was searching several sites seems to be your best bet.
Old 10-27-2014, 07:07 PM   #6
Geri
Hey,
thank you very much for the helpful comments and links.
Now the restore party can start
Best wishes
Geri
Old 01-03-2015, 07:28 AM   #7
Geri
Happy new Year.
I allready received my rebuild kit. But now i have a new problem with the roller bearings (needle bearings). Dissasembling was easy ....but the rebuild of this litte needles is very tricky.
Have someone special tricks for me to replace them?
Old 01-03-2015, 03:15 PM   #8
OrrieG
OrrieG's Avatar
I always use white lithium grease (Lubriplate) to hold needle bearings in place. Sticky enough to hold, but not to thick to affect spacing. Also is compatible with tranny greases and oils.
