![]() Join Date: Aug 2014
Rusty's Baseline Dyno Test
Decided to have my '74 GMC 1500 dyno tested before bolting on any shiny performance bits. Rusty is almost all stock except for a few things.
Specs: 350 V8 4 Speed Manual 4 Barrel Rochester Quadrajet No AC Modifications: LMC Truck 2 1/4 dual exhaust with Turbo Mufflers A.I.R. Air Injection Reactor System - Delete Here are the results of the three pulls: 1. 172 HP @ 4100 and 259 Tq @ 2600 2. 183 HP @ 4300 and 264 Tq @ 2900 3. 188 HP @ 4100 and 267 Tq @ 3000 * I am eye balling the RPMs for you This was my first Dyno Test for any vehicle and cost $80 at a place called Evil Genius Racing in West Sacramento, California. John is a super cool guy, if you are local you may want to check them out. |
Re: Rusty's Baseline Dyno Test
Nice baseline. Aren't these trucks rated at 185 hp anyway? How many miles on yours? Does it rev or pull past 4100 rpm or is that just where max power was? What gear to they test in? I assume 4th or 1:1 gear.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
Second Chance Program
Good base!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt. 77 C20 crew cab Silverado. 396/th400. In work. |
3 pulls for $80 correct?
#5 | |
160 @ 3800 RPM according to the 1974 Light Duty Truck Service Manual, I attribute the additional horse power to the less restrictive dual exhaust and the deletion of the SMOG systems
Odometer reads 34,457 so I am guessing 234,457 as it's hard to put on a ton of miles on a farm truck, probably not much highway driving Quote:
Good question, I don't know I will have to ask. |
just wanted to share a little trick John did for one of the pulls cause he thought the air cleaner snorkel is too restrictive
I am all about little tricks like that, maybe some of you have seen this done already, but I haven't, yet it is so simple (and yes my air filter is dirty as heck, going to replace it and the air cleaner housing next month) |
188hp at the wheels is not bad at all. Remember the old hp and torque specs were done at the flywheel not the wheels.
A computer once beat me at chess, but it was no match for me at kick boxing. Duct tape is like the force. It has a light side, a dark side, and it holds the world together. |
I'm impressed that it's putting down that much power stock. I ought to dyno mine eventually but with 350/350, 4.10s, and currently 30.5" tires it's no fun on the freeway.
1973 C20, 350/350 |
Just here to tinker
![]() Join Date: Jun 2008
That's awesome. I need to go have my non-turbo diesel tested so I can have a good laugh.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
#12 | |
78K & 79C Jimmys
but no all fit sounds louder too,I want to make one stocker a dual snorkel
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
The air filter flip has been around along time. I remember my dad doing it on his '69 El Camino. I did it on my new '77 1/2 ton stepside when I got back then.
If you have a truck with stock exhaust the intake sound when you open it up is far more impressive, especially in the cab. Happy Holidays and God bless, Terry |
What I have done is take the snorkel off the air cleaner. It is spot welded on. Them I take a piece of cardboard and trace the oval pattern and transfer one to the other side of the air cleaner and one in the back. Then the air cleaner has three large oval holes in it and retains the breather for the crankcase to the rocker cover. On models that have the breather inside the air cleaner base I just cut the entire bottom off of the air cleaner.
#15 |
nice nubers to start with. but i hope that you dont really think your truck is rusty??? i could show you pix of my c20 and my ramp truck that are on the road and pass inspection that make southners cry lol
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph 1985 k30 "the ice cream truck from hell" no rust az truck 197-8??? c30 "ramp truck" 454 1978 monte carlo 350 350th with 2.73 gears. no rust. sc car |
#16 | |
#17 |
This power curve is just perfect for the average driving that I do (now). 90% of my driving is between 2000-3000 rpm and the trans shifts at 4500 at WOT. I have to replace my cam this summer and I hope the aftermarket can supply me with a cam with max efficiency at 2500 rpm.
#18 |
#19 | |
![]() Join Date: Jul 2000
Mike 1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
