Old 01-04-2015, 12:59 AM   #1
Gregski
Gregski's Avatar
Quiz Time - Topic: Passenger Front Fender
How well do you know your Square Body?
How many bolts/screws do you have to remove in order to remove the passenger side front fender (by itself, nothing else hanging off of it) from a square body truck (73-87 third gen C/K I think) the screws that hold the badge do not count, etc.
A. 15
B. 20
C. 25
D. 30
Extra Credit: Let us know where the bolts are located that you would be removing
I hope I counted right, LOL
Gregski is offline   Reply With Quote
Old 01-04-2015, 11:48 AM   #2
Keith Seymore
Keith Seymore's Avatar
Re: Quiz Time - Topic: Passenger Front Fender
As a game changer be advised that the factory installed the fender with the wheelhouse already on it (the fender).
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 01-04-2015, 12:08 PM   #3
Gregski
Gregski's Avatar
noted, but it can be removed without the wheelhousing
Old 01-04-2015, 12:26 PM   #4
86c20
86c20's Avatar
i am going to guess 15. A final answer lol 5 on the back 2 for hood 2 at the top of core suport 3 in head light trim and 3 in the bottom fille and brace. and that is with not cheating and going out to look. to damn cold lol
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph
1985 k30 "the ice cream truck from hell" no rust az truck
197-8??? c30 "ramp truck" 454
1978 monte carlo 350 350th with 2.73 gears. no rust. sc car
86c20 is offline   Reply With Quote
Old 01-04-2015, 12:32 PM   #5
Gregski
Gregski's Avatar
not a bad start, the answer is more (5 on the back? not sure what you mean by those)
Old 01-04-2015, 01:59 PM   #6
86c20
86c20's Avatar
by the door. one in the a piller then 2 in the firewall and two at the bottom.
that is just a guess and that is with no inner fender or anything of the like.
i think if you add in the inner fender annd the plastic at the bottom and the batt try got to be over 25
Old 01-04-2015, 02:19 PM   #7
Keith Seymore
I installed about 1.8 million squarebody fenders (900,000 per side; or one per minute per side over a six year period) so I don't think it would be fair for me to participate in your quiz...
1979-1986
1986 - 2019
Old 01-05-2015, 02:22 AM   #8
Gregski
Gregski's Avatar
I believe it is 25, Keith correct me if I am wrong
here they are in no particular order
fist the big ones
3 - 9/16ths attach to the hood hinge bracket
1 - 9/16ths above the top door hinge
1 - 9/16ths under the truck door sort of
1 - 9/16ths on top behind hood hinges
then the smaller ones
7 - 1/2 inchers attach to the inner fender
5 - 1/2" attach to the radiator support on the inside
2 - 1/2" bolt on the side of the battery tray
2 - 1/2" above the headlight inside that cavity
1 - 1/2" left of the parking light inside that cavity
then the tinny ones
2 - philips screws hold the light bezel to the front of the fender
Old 01-05-2015, 11:43 AM   #9
Jaysonb
Jaysonb's Avatar
I found a front clip on craigslist the other day. I pulled it apart laying in the dirt and snow, there was at least 50 rusty bolts on each side, and they all had to be at least 3 feet long!! Can't wait to ditch my poor fitting aftermarket junk though.
Jaysonb is offline   Reply With Quote
Old 01-05-2015, 02:31 PM   #10
Gregski
Gregski's Avatar
LOL, awesome, so worth it though, thanks for sharing
Old 01-05-2015, 05:08 PM   #11
Keith Seymore
fist the big ones
then the tinny ones
Yep - I think you've got it.
(I would have forgotten to count the phillips screws - lol).
Those small 1/2" bolts are the ones I am talking about when I tell my favorite "bolt substitution" story:
Me too! Makes me crazy, especially when they argue about the finish on a bolt.
The attachment of the front fender "nose bolts" to the rad support was especially difficult, because it is blind and awkward access. As a result we would cross thread the bolts often or (worse) break the weld nuts loose. Major repair.
We found out that there were two suppliers for a bolt that same size: One from Lang Fasteners and one from Ferndale Fasteners. The Langs would crossthread like crazy but the Ferndales wouldn't (for some unknown reason). The Langs (part number 3846202, btw!) were black but the Ferndales were silver.
What we ended up doing was stealing a box of the silver bolts from Line 2 and run them all night with no issues, and then lock them up in our locker, (set out a box of black bolts on the job) and then go home.
We did that for several years. First shift could never figure out why we didn't crossthread and why they had a mess on their hands every day.
K
1979-1986
1986 - 2019
Old 01-05-2015, 07:07 PM   #12
Axle
Axle's Avatar
And if you have a fender mounted antenna you'll need to add one additional nut to remove the cable. Three phillips screws if you have the factory am/fm/cb antenna.
Alex.
Axle is offline   Reply With Quote
Old 01-05-2015, 10:42 PM   #13
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
You kill me. 1.8 million fenders.
Keith "I'll match your fender install, and raise you 1,799,999 fenders" Seymore.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 01-06-2015, 01:41 AM   #14
Gregski
Gregski's Avatar
(I would have forgotten to count the phillips screws - lol)...
stick with me Keith and I'll teach ya a thing or two, I must have removed not one but two of these bad boys already in my life time, soon to remove a third, JK
what about that 1/2" bolt substitution story? lemme get a beer
Old 01-06-2015, 01:46 AM   #15
Keith Seymore
I love you, man....
(lol)
Seriously though, if one were to do the math: 1 per minute = 60 per hour x 8 hours per day = 480 per day.
480 a day x 285 working days per year x 6 years = 820,800 fenders
x2 (one on each side) = 1,641,600.
...Assuming no overtime....
Plus: tightening the box down, hanging the spare, installing the M20 shifters and cab running lights, putting the battery tray(s) in and underhood wiring. And putting the SPID labels in the glovebox.
All in a day's work.
K
1979-1986
1986 - 2019
