![]() Join Date: Dec 2014
Re: cab floor
go to the junk yard and buy a couple of hoods or anything that is really flat and use the metal from that to patch in a floor.
but you'll need to know how to shape it, or cut and weld a lot! Otherwise, go to home depot and buy sheet metal. You will still need seat mounts that work. and you'll need to replace any rust under the cab so if you have really bad rust, take the cab off and do it the right way
69' Chevy C10 383 Stroker / TH400 275 55 r20 Wheels Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=654751 |
| Bookmarks |
