Front spring travel?
Does anyone know how much travel the stock c 10 springs (or frt. suspension) had new?
Re: Front spring travel?
you can see in the pic I only have about an inch of travel left. how much do you guys have on the stock front ends?
![]() Join Date: Jan 2011
Cut the snubber down or just remove it. On my 65 that entire bracket is gone.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
Never Ending Projects
My guess, looking at the angle of the lower control arms, your springs are either lowering ones (doubtful) or are sagging a lot. IIRC, the lower arms would be level or slightly down angle.
Also, keep in mind that 1" of travel at the bump stop is close to 2" of travel at the wheel. If you want more travel, you can remove the factory bump stop and add a short bump stop like I have. Works great. ![]()
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
Well chevy mike busted me. I cut one coil off. brought me down 2 in. I looked at the 70 c10 and it's only got 2 couple more in. stock. the springs look like they still have travel left and I did manage to get alignment, barely. seems pretty stiff though. drives good. I think I'll cut an in. off the bumpers. I'll probably "spring" for the drop spindles next time though. thanks guys.
Okay, that makes a lot more sense. I was really happy when I did a half cut coil and 2" drop spindles. Road great and no issues with bottoming out.
