Old 01-06-2015, 09:04 PM   #76
NoClassic
Re: 1958 3200 Long Bed 5.3l/Jag IFS
gray 3m scoth brite pad and microfiber rags for cleanup
I will probably apply wax to the areas that retain some paint once the whole thing has been gone over with the CLR.
NoClassic is offline   Reply With Quote
Old 01-06-2015, 09:11 PM   #77
Kim57
Kim57's Avatar
That's looking real nice.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 01-13-2015, 10:11 PM   #78
NoClassic
The bends for the radiator showed up so I fitted all the tube for the upper line. Once a 1.75" 120 degree shows up I will finish the bottom and then take them to be welded.
With a majority of the weight now on it I also checked and set the axle pinion angle. I may wait to weld everything until after the doors and glass just to be safe though.
The glass guy also came by to make a pattern for the rear so that should be happening soon.
Old 01-14-2015, 09:47 AM   #79
Kim57
Kim57's Avatar
That's going to look real nice when done.
Kim
My build thread
Old 01-16-2015, 09:37 PM   #80
NoClassic
My friend welded up the coolant pipes for me yesterday and the hose clamps showed up earlier today. I also picked up a reservoir and got in mounted.
The glass guy came by and did the rear piece. He had trouble finding a non tinted windshield but we should have it next week.
Old 01-16-2015, 10:23 PM   #81
joedoh
joedoh's Avatar
nice work!
Old 01-17-2015, 10:40 AM   #82
Kim57
Kim57's Avatar
Looks real good.
Kim
My build thread
Old 01-19-2015, 10:21 PM   #83
NoClassic
We had to pull the front bodywork back off to swap out the springs that were in it. They ended up being too low causing the upper ball joints to bind. This was a surprise considering what I had read about others experience with subframe mounting height. I have a feeling I am not going to be happy with the final ride height, but not much that can be done at this point.
On a positive note the glass guy came by and did the windshield for a very reasonable price.
Old 01-19-2015, 11:50 PM   #84
Dan in Pasadena
Dan in Pasadena's Avatar
Everything looks really well done, huge congrats!
May I ask: did you shoot the firewall & inner fenders with an automotive type paint through a gun or was it done with rattle cans? Same question on the bed liner or undercoat you used on the steps?
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 01-20-2015, 12:03 AM   #85
NoClassic
The engine bay is an Omni brand black epoxy primer shot from a cheap harbor freight gun. I am really not that happy with it to tell you the truth. I had used SPI brand epoxy on another cars engine bay and expected similar quality from the Omni. It is pretty soft for an epoxy and if I did it over I would use another brand.
The undercoating is a a textured (little pieces of rubber) polyurethane from a company called durabak. I have been pretty happy with it overall. It has cured pretty hard for a polyurethane and went down easy. I just used a cheap undercoating gun of amazon.com to spray it.
Old 01-24-2015, 01:12 AM   #86
NoClassic
We have just been cleaning up small stuff in the interior, looming the under dash harness, and diagnosing an issue we had with the rear turn signals and brake lights. It ended up being the aftermarket bulb sockets so we just ordered new housings.
I also painted the last of the interior trim along with the steering wheel after completing the repairs to it.
Old 01-24-2015, 12:29 PM   #87
Kim57
Kim57's Avatar
The wheel came out real nice.
Kim
My build thread
Old 02-04-2015, 07:35 PM   #88
NoClassic
The doors are now hung and adjusted. We still need to get the latches working, but that may mean a new set of strike plates with the condition the existing set is in. The wiper motor showed up and is now installed and working. I used more CLR on the rest of the bed and we are just about done getting the wood back in it.
Old 02-05-2015, 09:14 AM   #89
Kim57
Kim57's Avatar
The bed wood looks nice.
Kim
My build thread
Old 02-19-2015, 04:48 PM   #90
NoClassic
We replaced one of the door latches so they both function now. The door panels went on and today I did the final gauge install. My dad finished up filling and sanding all of the repairs to the body. If its warm enough tomorrow I will start painting everything.
I think we should be able to start driving it within the next couple weeks.
Old 02-19-2015, 05:06 PM   #91
RockinKees
RockinKees's Avatar
Nice dash!
I do like your coolant pipes too!
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 02-19-2015, 05:41 PM   #92
Kim57
Kim57's Avatar
The dash looks real nice.
Kim
My build thread
Old 02-19-2015, 06:32 PM   #93
NoClassic
We just got done letting it come up to temp and idle to check for leaks and top off the trans fluid.
No leaks and everything sounds good with the motor.
Old 02-19-2015, 09:09 PM   #94
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Dash looks good! I see some vintage hubcaps on the floor?
ChuckDriver is offline   Reply With Quote
Old 02-19-2015, 09:32 PM   #95
NoClassic
They are the same caps I posted earlier in the thread.
Old 02-19-2015, 09:54 PM   #96
ChuckDriver
Oops, I furgit!
Old 02-25-2015, 09:06 PM   #97
NoClassic
I sprayed epoxy primer over the areas we repaired on the cab and got the hood shimmed and installed. I also set thel pinion angle and did the final welds on the axle.
We are going to get the bed on over the weekend and drive it to have the firewall color scanned so we can get an exact pain match. It has been off twice trying to match what good paint remained on the tailgate.
Old 02-25-2015, 09:48 PM   #98
Kim57
Kim57's Avatar
The white wheels look real nice.
Kim
My build thread
Old 02-26-2015, 06:26 PM   #99
NoClassic
My Dad finished up some stuff with the bed earlier today and I just helped him lift it onto the chassis. I am surprised we were able to get it on there but all that is left now is countersinking the offset washers and a couple shims.
I will try and get some better images this weekend.
Old 02-26-2015, 11:29 PM   #100
Kim57
Kim57's Avatar
Looks real good.
Kim
My build thread
