Old 01-05-2015, 02:42 PM   #1
c20pickup
Differences between c10 and c20 springs
What are the differences in c10 and 20 springs, front and back? Can i take a drop spring from a c10 and put in my c20? Not worried about hauling capacity because the truck wont do any hauling. Looking to drop the front 1 inch and the rear maybe 2-3 inches.
c20pickup is offline   Reply With Quote
Old 01-05-2015, 03:00 PM   #2
markmdz
Re: Differences between c10 and c20 springs
subscribed. i'm interested in the same.
markmdz is offline   Reply With Quote
Old 01-05-2015, 05:33 PM   #3
65standard
65standard's Avatar
I put half ton springs in my 3/4 ton, just to soften the ride.
Tony Nicholas @ Midwest Metal Masters
1953 Chevy 3100 392 Hemi w/727 & 9” Ford
1985 Chevy C/10 6.0L 4L80 373 locker
65standard is offline   Reply With Quote
Old 01-05-2015, 10:08 PM   #4
c20pickup
Did you have to chamge anything? A softer ride would be a plus, but also a small drop would be nice, and nobody makes a 3/4 ton drop, so that leaves me looking at 1/2 tons
Old 01-05-2015, 10:11 PM   #5
65standard
65standard's Avatar
Direct replacement.
Old 01-05-2015, 10:57 PM   #6
Zable49
Zable49's Avatar
Check out the attachment. Explains coil spring differences.
1970 C20 Camper Special
SBC350 / TH350
'84 C20 Front Disc Brakes/Control Arms
Zable49 is offline   Reply With Quote
Old 01-06-2015, 11:08 AM   #7
c20pickup
Wow, lots of info in there... I think i will order up spme 2 inch drops for the rear, or maybe just block it and order 1 inch drops for the front, hopefully this will level the truck out
Old 01-06-2015, 02:22 PM   #8
Coley
Coley's Avatar
Smile Re: Differences between c10 and c20 springs
Thats a really good document...very interesting.
I think there might be a typo tho' in the second paragraph where it mentions that H.duty springs are generally designed to carry 3% to 5% more load. I think this should be 30% to 50% greater load capacity. The 3-5% number doesn't work with the capacities listed below in the document. Great info tho' on the specs listed!!...very helpful.
All Good
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 01-06-2015, 03:19 PM   #9
markmdz
Indeed a very good intro to springs. For the first paragraph or so, I could swear I was reading one of my old articles, aside from the use of 'variable' rather than 'progressive' as the common term. For a number of years I was the 'suspension guy' in a car group I use to be very active in.
Anyway, the specs on the C10/C20 springs are VERY helpful.
Just for a point of clarification, can anyone confirm the "Load Height" and "Free Height" values?
Does the Free Height indicate the height of the spring off the vehicle or the static height of the spring while in the vehicle without any additional load (i.e. Preload)? Same with the "Load Height"... Does that indicate the the height of the spring while at Preload, or the height of the spring at the indicated Design Load?
I assume the Free Height is the height of the spring uninstalled. I'm curious to know what the Load Height value is showing. Either way, with that Free Height assumption, I'd caution anyone to buy a set of springs based on the Free Height and assume they're going to raise or lower their vehicle. The most important value to know when determining how much it'll raise or lower your vehicle is the Preload height, assuming an otherwise stock vehicle with no additional loads factored in.
Old 01-06-2015, 10:15 PM   #10
slow-1
slow-1's Avatar
I could have sworn I've seen 3/4 ton lowering springs for sale somewhere, but I can't find them using this dang phone.
1972 Cheyene C-10 "Ole Green"
My Grandfathers truck (early 70's to 1983)
My first vehicle (1983)
Original 350 (3 rebuilds)
700R4 from Bowtie Overdrives
slow-1 is offline   Reply With Quote
Old 01-06-2015, 11:17 PM   #11
69SCSS
69SCSS's Avatar
CPP sells a 4" drop "Heavy duty" spring set. I have them on my truck, and honestly I don't think they're even 1/2 ton rated. I'm considering swapping in 5" drop springs instead. I've heard they're inconsistent.
My 68 SWB
Al Silveira Music
<- My daughter loves this guy 8-)
69SCSS is offline   Reply With Quote
Old 01-06-2015, 11:24 PM   #12
Zable49
Zable49's Avatar
You might have wrote some of the information, trust me I am not taking credit for any of that information I found this info here: http://www.67-72chevytrucks.com/vboa...d.php?t=336257.
I personally just like to find data about a topic and save it under a WORD DOC. That way if I ever need something I know where to find it, hence COIL SPRING document (well in this case a PDF).
SBC350 / TH350
Old 01-06-2015, 11:33 PM   #13
c20pickup
everything i find is too much of a drop, being a c20 the rearend sticks way up into the sky, i want to drop that maybe 2-3 inches, and the front about 1 inch, leaving it somewhat factory height, mostly level with a very slight rake. maybe i will block the rear with some 2 inch blocks and cut the coils up front, or try to unt down a set of 1 inch drop spirngs for the front. might even ditch the blocks for the rear and find some 3 inch springs for the rear. i wish there was more options for a slight level and drop.
