#26 |
Re: New to these trucks 1948 thriftmaster build.
Wow! Day and night transformation. Nice job sickred72.
#27 |
pic of the engine and rear wheels
#28 |
Welcome from So. Arizona!
What are you doing trying to beat the 1/2 hour TV shows !! I read all that build in 5 min.!! Looks like you will be driving that truck in a week at your speed!! Before you weld the front crossmember in you may want to mock up the R&P and see if the bellows clear the bottom of the frame, unless you are planning on welding in noch. I guess with the super slam you will be doing that anyway. Super simple on the Scotts products!!
#29 |
Rack notches are with his kit
Justin |
#30 |
Your project is looking good
Justin |
#31 |
Your project is great. Good progress and choice of parts. What are you planning for an engine?
I a doing a 48 GMC and I am about as far along as your pix show. I used a M2 front end with a power rack. I also will use the 235 straight six that was in it. Going to keep the vintage early 60's style. It had split fentons and a 2x Offy intake on it. I was sold when I saw it in a salvage yard. Body is rough but reat is pretty good. Asking about the engine because if you reuse the sis you will most likely have to redo the motoe mounts to raise the engine to clear the rack. That is whjat I am fcing at the moment. Test fitted the engine last night, just back from rebuild, and saw the crash withe the rack. TCI, the manufacturer was not much help. I am on my own to solve. They did suggest a fabricator for the motor mounts. I am sure there are a bucnh of watc outs when doing this. That's where I am at. Keep up the good work. |
#32 |
I just went back through your pictures and saw your engine. Never mind my comment on the rack interfearance.
#33 |
got an early start today! got the rear bedsides cut out for the mini tubs, now i can measure for my rear end...got rid of the rear fender braces because everyone says i dont need them. should lay flat ass on the running boards!
#34 |
This is gonna be a sweet looking ride when its done. Like where you are going with it. Looking good so far.
#35 | |
I was at his garage to pick up some parts. First thing I said to myself was cool garage. Wish I had that much space. Nice progress so far The work I saw when I was there was first class. |
#36 |
![]() Join Date: Mar 2011
looks killer mate. The budniks look insane. Cant wait to see it on the ground.
Blake. Sydney Aus 56 Chev 3100 build - http://67-72chevytrucks.com/vboard/s...d.php?t=480363 LOW n LOUD ![]() |
#37 |
![]() Join Date: Jul 2010
Man that was sweet before, but it will be killer when it done..love tha wheels
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
#38 |
A320 Pilot/USAF Retired
Killer build!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
#39 |
gorgeous
