Roto Reuter thats the name...
![]() Join Date: Feb 2010
Auto trans decision help for my new LSx build
Hey guys, I am beginning work on my first frame off with LSx install on a 71 SWB. I'm having a custom chassis built by Scott's Hot Rod. I haven't determined my exact engine yet, but I plan to look for a new GM engine/trans package. I decided to go with an automatic transmission and Scott's recommended setting up the chassis for a 4L60e transmission. Can you give me any insight on if this is a good way to go? from what little I know, it sounds like the 4L80e is a stronger transmission, but may be bigger and heavier. What are my options, and what would be a good way to go? Right now I am considering possibly new LS2 or LS3 engine/auto trans combo. Please help me with my auto trans options, so I am able to get the chassis set up properly. I will need to get back with them before they move too far along with fabrication. Thanks.
~ Dan ![]() My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
Re: Auto trans decision help for my new LSx build
4L80E, If you already had a 4L60E I would suggest upgrading it. But your early in your build....
![]() ![]() i thought so .50 bmg all the way and that is the 4l80e.... 4L80E and never worry about the tranny unless you pushing ridiculous power.... ![]() post pics of your build and whatever drivetrain you end up buying! take it easy |
Hmm… I wonder why Scott's would recommend using a 4L60e. They said it's bullet proof and usually used on these builds. I guess I will continue researching. Thanks for the comments. Keep the feedback and opinions coming please.
A built 60 can be very strong, but a factory one might be lacking. The setup I'm looking at sadly comes with a 60, so I'll probably get it going with that and then if anything happens (or if I add any power) I'll swap to an 80.
The size/weight difference is there, but it isn't a big deal in a truck. One advantage of the 60 is gearing, it has a lower 1st gear and a higher overdrive.
1973 C20, 350/350 |
#6 | |
If you are beating on it and taking it the track regularly the 4l80e may be a better choice . If buying a new trans you may look into a 4l60e or 4l70e from finish line transmissions . They have several different levels of builds . I have there level five . This may also be a little easier to set up with a stock pcm . It was a plug and play for me with my 04 truck operating system . This option would not cost that much more than a stock trans new . If you do use a stock 4l60e and have problems just get it built to suit your need down the road . I have seen people beat on the stock ones pretty bad and they are still holding on. The key is get it tuned to help it survive and a trany cooler. Heat is mostly what kills them during performance . Last edited by homemade87; 01-07-2015 at 01:36 PM. |
If you can afford a custom chassis then I would say pay a few extra bucks to go with a 4l80. You wont have to worry about it going out and you can do everything a 4l60 could. If you plan on going overkill with the engine then take a look at Jake's Transmissions.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
#8 | |
Boosted Member
I've personally destroyed more 4L60s at moderate power than I care to recall. If you are making any sort of power, and keep it on slippery tires, it might last a bit.
If you have the choice, set it up for a 4L80E and call it a day. Not sure if serious? Did you change your tune, Cline? haha j/k.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
meowMEOWmeowMEOW
HAHAHA I was gonna point that out. Cline not championing the 4l60e!?! I gotta go buy a lottery ticket.
The cool part about the 4l60e is that they tend to fail in SPECTACULAR fashion.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#11 | ||
![]() But money wise....Since he has not yet bought a trans or the Chassis set-up, The 4L80E would be a wiser choice. This car finally broke the 4L65E that I built a few years ago, The Output shaft broke at the input planet, But at well over 500 passes & hard street driving, The rest of the unit looked good! Another customers '05 Silverado SS, LQ9 with a L92 top end, Cam & long tubes has been beating on his stock w/ a good converter 4L65E for a couple years now, The truck had 100K on it when the engine mods were done. Now to eat some crow.....Customer brings in a '84 Chevy C-10 Cammed LQ4 with 3-4's out of the 4L60E, Burned up 3 of my transmissions in 2 months. Took a ride with him driving on the 4th trans, Completely abusive/No driving prick....3-2, 2-3, 3-2, 2-3, 3-4, 4-2 over & over again, I thought. his foot would cramp up. He was overheating the 3-4 clutches on purpose in my opinion...............However I told him I can build a trans to hold up. I installed a 4L80E 100% out of my pocket, That hurt! |
I spoke with Justin at Scott's Hot Rod and asked him if they could provide a transmission crossmember that would accept both 4l60 and 4l80. He said they've never done that before. They've only provided mounts for either one or the other, but they agreed to provide one that would accept both. That takes the pressure off me, at least for the time being.
Hey man thats good to hear that the company is willing to accommodate your need. Good luck on build, i too have crossmember issues.. Ls swap learning curve!
#14 | |
meowMEOWmeowMEOW
#15 | |
#16 | |
Boosted Member
![]() For my budget, it's hard to beat a $200 junkyard 80e with a $120 HD2 and a nice converter.
#17 | |
#18 |
Boosted Member
I think you're making it into something bigger than it is. Brew is not wrong. It may just be as simple as flipping the trans crossmember 180* in the frame to make up that 4-1/4". At the VERY MOST, it would involve welding an extra set of tabs to the frame to accomodate a different position for the trans crossmember. This is of course assuming that they make the trans crossmember removable. I'd hope that would be the case on a high dollar kustom built chassis like that.
#19 | |
#20 |
Regarding crossmember...
I currently have 350/350 and will probably go to 4.8/4L60 with a possible upgrade to 4L80 down the line. What will I need to do for tranny mounts?
1973 C20, 350/350 |
#21 |
Boosted Member
Unbolt...slide to new location....drill new holes....do burnouts.
#22 |
I'm not sure how I would flip the transmission mount on a custom made chassis. Any ideas?
#23 |
I would ask the fabricator to make that a bolt in crossmember. You said it's just gonna be a cruiser plus when that 4l60 eats it it'll be a lot easier to swap the trans.
#24 |
I'm guessing the factory crossmember is riveted, so I'll have to grind them off, but if that's the basic procedure it doesn't sound too bad. How far back will I have to slide it?
1973 C20, 350/350 |
#25 | |
Boosted Member
Unbolt at 1 and 2, and either flip it 180* as shown in step 3, or make a new piece to bolt in to location 1 and 2. How's that for an idea? ![]() ![]()
