Old 01-03-2015, 10:47 PM   #1
rs74
rs74's Avatar
Long bed to Short bed thoughts?
I am looking at an 85 long bed diesel silverado that is in pretty decent shape for the most part. It does have some rust in the bed. I would like to have a long bed but thinking about a short bed instead. I have found a short bed and frame for about $300. I am thinking that if I am going to have to do body work on the long bed then maybe just buy the short bed and have it painted to match.
To cut to the chase here and opinions are probably going to be a little of each. Should I just think about cutting down the long bed or switch everything over to the short bed frame. I would probably break even between fixing and painting the long bed and just buying the short bed and painting to match the cab other than doing all the transferring of parts.
I have been looking for a 6.2 truck just for mileage purposes since I would be making it my daily driver while the K30 dually serves as the pack mule and my 85 short bed is in the middle of a rebuild. So cut it down or put switch everything over to the short bed frame.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 01-03-2015, 11:02 PM   #2
Ziegelsteinfaust
Re: Long bed to Short bed thoughts?
I would do it if I planned to keep the truck.
Ziegelsteinfaust is offline   Reply With Quote
Old 01-03-2015, 11:29 PM   #3
Just call me Sean
Just call me Sean's Avatar
I would switch the frame.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 01-04-2015, 01:00 AM   #4
rs74
rs74's Avatar
Haven't bought it yet but if so it would be used as a daily driver.
Roy
1987 R10 shortie
Old 01-04-2015, 01:06 AM   #5
Gregski
Gregski's Avatar
I don't know squat but the questions I have are, are both trucks C10, 20, 30s? Did they make diesels in each. If it is like a 20 to a 20 then you could do it but if you are going like a 30 to a 10 then that's a more complicated job I recon
plus diesels are more of a work truck and working men prefer long beds I recon, so you would devalue the diesel, if you care about that type of stuff, some people don't
bottom line these trucks are cheap and yes you can still find them, so I say fix what you got but don't do the swap, if you want a short bed find one and buy it, you will have plenty to fix on it without a frame cut or a swap
Gregski is offline   Reply With Quote
Old 01-04-2015, 01:10 AM   #6
rs74
rs74's Avatar
They are both C10 trucks. I would take gas or diesel for a daily but the diesel should get a little better mileage.
Roy
1987 R10 shortie
Old 01-04-2015, 11:35 AM   #7
KrazyRay
KrazyRay's Avatar
I would do a frame swap. I have done a few where I would lift the cab/front clip and engine/trans together, roll the long bed out and roll the short bed in.
KrazyRay is offline   Reply With Quote
Old 01-04-2015, 12:37 PM   #8
68Timber
I know the pieces fit
68Timber's Avatar
$300 sounds like a good deal for the bed and frame. But is it a roller? If not, cutting the longbed may be less labor than swapping all the suspension over.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 01-04-2015, 01:24 PM   #9
enaberif
The problem that some people face like myself is that short box 4x4s are a needle in a haystack and even in rough condition they go for far too much money.
You can find long box 4x4s all day long and at the end of the day cutting the frame makes more sense and is far cheaper in the end.
enaberif is offline   Reply With Quote
Old 01-04-2015, 01:52 PM   #10
Just call me Sean
You don't need to weld to swap frames.
Old 01-04-2015, 04:20 PM   #11
KQQL IT
At the body shop.
KQQL IT's Avatar
If you cut the frame there won't be any vin# issues.
If the short bed frame is a roller would be easier to swap.
Old 01-04-2015, 04:25 PM   #12
rs74
rs74's Avatar
There wouldn't be any vin issues either way. There are no inspections here. Body shops swap frames all the time with no issues on collision repair.
Roy
1987 R10 shortie
Old 01-05-2015, 01:27 AM   #13
UKNOWME
UKNOWME's Avatar
So is the short bed a roller? If so then do the frame swap.
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 01-05-2015, 01:46 AM   #14
Oregoon
Roadside Rebuilder
Oregoon's Avatar
Personally, I prefer long-beds, unless it's a short-narrow. I love those trucks, but only from '67 up. And I still like a long-bed fleetside better than anything. But I grew up around logging, construction and such, so my tastes always run to utility.
And even lowriders, muscle-trucks, etc, I still think a long bed looks better.
That said, there's a lot of cool shortbeds on here and ultimately, it's your truck, so you do as you please. That's always the coolest build, if you ask me... Suit yourself and be stoked on the results! I for one will be equally hyped for you!
Oregoon is offline   Reply With Quote
Old 01-05-2015, 12:56 PM   #15
rs74
rs74's Avatar
Yes it is a roller.
Roy
1987 R10 shortie
Old 01-07-2015, 06:20 PM   #16
rs74
rs74's Avatar
It no longer matters I guess. The truck sold and it wasn't to me. On the look we go again.
Roy
1987 R10 shortie
Old 01-08-2015, 06:09 AM   #17
andrewmp6
Gm had the 6.2 diesel option for all trucks,If you can weld and can do it shortening the frame would be less work.If you can't weld and have to pay to have it done i would swap everything over to the swb frame.
