Old 01-08-2015, 07:30 PM   #17
lindstromjd
Gentleman Jim owner x2
lindstromjd's Avatar
Re: 5.7 vortec rpm "slip"
Originally Posted by speedygonzales View Post
You need to be looking for your "missing" push rod. During an oil change, try using something like a hanger through the drain hole to see if you hear something sliding around the bottom of the pan. You may have bigger potential problems than just a misfire.
BTW the actual method for tightening rockers is to use your fingers to roll a dry pushrod back and forth while tightening the nut until you feel drag on the DRY push rod. Once you have drag, you tighten the nut 1/2 turn further.
Has always worked for me for many many years. Doesn't make the "running" engine oil mess either.
I had it at the shop after I replaced it, and they had the intake manifold off and didn't mention anything about finding pieces of a pushrod. I have no clue what happened to it.
I know that method, but I've always heard that it was a "get it close" method and then once the engine is running, back them off until they start to chatter, and tighten them back down again until they're quiet.
1975 GMC Gentleman Jim #1
-357 / 700r4
1975 GMC Gentleman Jim #2
-350 / TH350
lindstromjd is offline   Reply With Quote
