Old 10-29-2014, 09:13 PM   #26
clinebarger
Re: 6l80e drive shaft ?
Originally Posted by kotapug View Post
I just had a yoke from a 6l80e truck machined for my ls swap out of a 2011 camaro
From someone that works on vehicles everyday, That is a Bad idea!
You will have the press the U-joint on with the Yoke on the Transmission. This will be easy from the top without the cab & exhaust. But try to do that from under a finished truck.
clinebarger is offline   Reply With Quote
Old 10-29-2014, 10:31 PM   #27
jjzepplin
jjzepplin's Avatar
Didn't think of that. Looks beefy though.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 10-30-2014, 04:01 PM   #28
DLW
What size U-joint does that take?
does that act as a slip yoke or is it bolted on the tail shaft like the stock 3 prong is?
DLW is offline   Reply With Quote
Old 10-30-2014, 08:16 PM   #29
nsb29
nsb29's Avatar
its a bolt on yoke, that's why you have to use the 400 bolt on yoke the 6l80e slip yoke is not right because you will half to press the u joint together in the truck the 400 that I used bolts together like the differential end look at the pictures and you will see what we art talking about. P S the slip is in the drive shaft like the 4by4s
nsb29 is offline   Reply With Quote
Old 10-31-2014, 11:32 AM   #30
DLW
Ok, thanks for answering my next question about where the slip is coming from..
BTW, do you have a part number for that TH400 yoke? and what did you have machined? Just matched the 3 prong?
Edit: Ok, I see the link for it now that Clinebarger put up for the 400 yoke.
Old 10-31-2014, 08:07 PM   #31
nsb29
nsb29's Avatar
:yep just take your 3 flange yoke to the machine shop w/your 400 to go by, the 400 BOLT ON yoke can be found on ebay
Old 01-08-2015, 08:04 PM   #32
Gooker928
I had a th400 yoke welded on.
Gooker928 is offline   Reply With Quote
Old 01-08-2015, 10:15 PM   #33
l92powered77
Thumbs up Re: 6l80e drive shaft ?
This is the tailend of my 6l80e.supposedly its the tail end of a sts-v. Has anyone seen this version? I got tranny off craigslist had no idea it had this done to it.now having trouble with mounting it to xmember.
First pic is tail end and second pic is the mount this guy had made for it. check this out..local drivetrain shop said they wouldnt have problem making me a custom driveshaft.
l92powered77 is offline   Reply With Quote
Old 01-08-2015, 11:00 PM   #34
l92powered77
Exclamation Re: 6l80e drive shaft ?
So basically i have to find a 400 yolk as a.connector to driveline and heavy-duty u joints??
