Cluster King
![]() Join Date: Nov 2012
Serp belt conversion ?
Looking to find out from all of you that have done a serp belt conversion on a small block to which fan shroud you use.
Can you post photos that show the fitment and explain any issues you had. Thank you in advance, Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
![]() Join Date: Mar 2003
Re: Serp belt conversion ?
When I did my swap I used a big block shroud. I also had, at the time, an extra set of big block frame stands, so I moved the engine back. Fan placement worked out perfect
![]() Join Date: Jul 2014
Here is my set up, small block with 4 core radiator, pulled the shroud off a junkyard truck, not sure ifor it came off a big or small block.
i used a stock sb shroud. the only modification I did was a small notch in the bottom of the shroud to make it easier to get past the water pump pulley.
mine looks just like the pic in the above post so no reason to post another one. I also used the Camaro/caprice brackets, the space the alternator and a/c compressor out to the side more than the truck brackets. if you do a swap, pull the radiator before you start and make it the last thing you re-install, its a lot easier to drop the radiator in last than it is to fight installing the fan and belt through the shroud
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies 2004 2500HD utility bed aka Brutus |
I did the swap, one of the best mods in my opinion. The stock fan for the serp systems are 19" and will not fit in the stock shroud. You'll need to find a 17" to use a stock shroud. I got mine from Derale.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 Last edited by Lee H; 01-10-2015 at 10:45 AM. Reason: Typo |
