01-07-2015, 09:29 PM | #126 |
Re: Free Candy Inside: 63 Long Panel Build
Got a snow day today (teacher perks) so I headed out to the garage. Started working on mounting the body. Made an outboard mount
01-07-2015, 09:30 PM | #127 |
Got it mounted up
01-07-2015, 09:32 PM | #128 |
Then I started working on mounting a tank. Picture looks off, but everything is straight and level. Lol
01-08-2015, 07:01 PM | #129 |
How come my teachers couldn't have been this cool?! What grade do you teach? Thermal Dynamics plasma cutter ain't no chump change. Maybe I need to do a career change!!!!!
01-08-2015, 10:00 PM | #130 |
Haha. I teach high school health and phys Ed. This is my 5th year teaching. I actually got the plasma cutter really cheap. Like $200ish chea (I got it in a package deal with the welder I got off craigslist). Problem is the guy didn't have 220 at his place so I couldn't test either one. Took my chances. Welder works great. Plasma won't stay lit/cut. It just sparks the whole time. I changed the consumables but it didn't make a bit of difference. I took it to a buddy's house thinking maybe it was a power/air pressure/moisture in the line but it did the exact same thing at his place. A buddy took it to his work hoping to fix it.
01-08-2015, 10:05 PM | #131 |
Got another snow/too cold day. Got the tank mount finished. Also got the other side outboard mount started before I ran out of mig wire. Cleaned up the garage.
01-10-2015, 02:23 PM | #132 |
Cool build so far. I am curious about your gas tank. On a SWB suburban the filler is behind the rear wheel. Is your tank between the frame rails or outside? Do you have pictures?
Dale ---------------- My suburban's Twisted Little Sister http://67-72chevytrucks.com/vboard/s...d.php?t=655167 |
01-10-2015, 05:55 PM | #133 |
On this one (c20 or 30) the gas tank was mounted right behind the drivers seat outside the rail. I decided to leave it in the same spot but made/making a custom stainless tank.
01-10-2015, 06:02 PM | #134 |
Here's a pic of the custom tank that's going in it. The fatter end goes toward the drivers seat. The skinnier end is notched to go around my 4 link. Figure it's going to be roughly 15gallons.
01-10-2015, 06:05 PM | #135 |
Here's another pic. Baffles will be inside. I still need to figure out how I'm going to mount it, filler neck and securing the pump. I bought a piece of stainless at my local scrap yard for $40. Made a template and then went to a local shop that sheared it and bent it up for me for $40. Custom stainless tank for $80 thus far.
01-10-2015, 09:30 PM | #136 |
I pmed you
01-11-2015, 03:33 PM | #137 |
I just set the bottom and side piece of the gas tank in the truck so you can see how I made it to go around the 4 link set up. Not sure if this helps you any.
01-11-2015, 06:58 PM | #138 |
Nice work on the new tank. Thanks for the pics. For the fuel pump have you looked at the Aeromotive Phantom in tank pump. Installation looks relatively easy.
01-11-2015, 08:57 PM | #139 |
01-12-2015, 08:06 PM | #140 |
Got another snow day today lol. Got out to the garage and got my transmission crossmember done. I had one in previously but the angle was off and I had no way of running exhaust.
01-12-2015, 08:09 PM | #141 |
Because I wanted it as low as possible I decied to use a couple 1/2 inch thick energy suspension body bushings to dampen it to the mount. Here's it installed.
01-12-2015, 08:13 PM | #142 |
And it looks like I will now have plenty of room for exhaust now. I used some 2" pvc to mock that up. Lol
01-12-2015, 08:59 PM | #143 |
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
Looks like that will work!
Nice!
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=512904 |
01-13-2015, 06:34 PM | #144 |
When grinders attach! Was prepping some metal I couldn't clamp and it bit me. Looks worse than it is. Rinsed it off, a few bandaids and back to work. And yes, I had gloves on when this happened
01-13-2015, 07:36 PM | #145 |
Ouch. Been there, done that..more than once too. Glad it wasn't too bad.
01-13-2015, 07:44 PM | #146 |
Now that got my attention
my rides 59 GMC Apache fleetside http://67-72chevytrucks.com/vboard/s...d.php?t=684337 68 VW Westy camper |
01-13-2015, 08:35 PM | #147 |
01-14-2015, 10:55 PM | #148 |
Today I bought a bunch of wire, some relays, and some odds and ends to try to get the air ride done. I messed around too much and only got the valves installed and the tank set in place. Hopefully tomorrow Ill get the compressors mounted up and do a little wiring. Going to be a simple set up. Accuair is cool and all but to me that's just way too much stuff to go wrong. Even if I was rich I'd still do a simple set up with just an few switches.
01-15-2015, 11:16 PM | #149 |
Tonight's progress: made some compressor mounts
01-15-2015, 11:20 PM | #150 |
And heres it together
