01-27-2004, 07:00 AM | #1 |
Decided to cut my factory springs..logic behind this...
Yessem', I've decided, that I'm going to tinker with my factory springs. Seeing as I have 255/55 17's up front, and the fender is nowhere CLOSE to touching the tire with a 3" drop spindle, I'm gonna cut a little off the spring, to get it within 1" of touching. I may have a LITTLE rake after doing this, but this is going to give me the idea of if I want to take off my headers and go lower than 4" of drop, or stick with 4" of drop.
Trust me, I'm buying new springs, just wanna see how it'll look first, since the truck doesn't get driven much. It won't matter |
01-27-2004, 08:49 AM | #2 |
Live from Atlanta
IMO, go ahead and buy the drop springs and be done with it. If you are already planning on getting the drop springs, why perform the event twice?
You said this in another thread about stereos... "I wished I had a stereo in my truck again...Hmm..Best Buy is running an ad this week for 4 6½'s for $60, might have to go pick those up, then get a DEH-1500 for $80 from a local shop. At least then I'd have SOME tunes." Take that $140 and go get some springs. BTW, did you ever change out your cab mount bushings??
Paul Last edited by Low87on20s; 01-27-2004 at 08:55 AM. |
01-27-2004, 09:37 AM | #3 |
My opinion, you won't like the way that rides on cut springs........be more like a lumber wagon.....
Bought one that had been done that way....ended up changing the springs.
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
01-27-2004, 09:38 AM | #4 |
You know to cut them with a cut-off wheel or a plasma torch right?
01-27-2004, 12:45 PM | #5 |
Under construction!
Don't waste your time, Tim.
Either go 5/7" or bag it.....simple as that.
2001 Silverado bagged on 22's. *Sold* |
01-27-2004, 01:14 PM | #6 |
Trucker.
Drop springs aren't that expensive.
01-27-2004, 02:04 PM | #7 |
i don't think you will have a problem just trying to lower it an inch by cutting. i'm going to cut my passenger side spring to drop it about 3/4 inch b/c it sits that much higher than the drivers side. i doubt taking 1/4 or less of a coil off is going to turn something that rides good into riding like crap. it would be different if you were gonna hack a full coil off and try to drop it like 3 inches by cutting, but i don't think you will have a problem.
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
01-27-2004, 02:10 PM | #8 | |
driving is in my blood
I tried cutting the springs once in high school, I couldn't get it right. Bending the bottem back flat is quite hard if you have no idea what to do
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
01-27-2004, 02:16 PM | #9 |
Mudslides 'r my specialty
I wouldn't do this simply because of the time involved. Just buy some new springs and do it once.
How long would it take to do this once? Multiply that by how much you make an hour. It would probably be enough to pay for a new set of springs.
Always on the lookout for old cars and parts...(20s, 30s, 40s, 50s, 60s, etc.) http://www.cardomain.com/memberpage/500339 |
01-27-2004, 02:31 PM | #10 |
i could take my spring out, cut it, and have it back in in 30 min. lol, i think drop springs are more than 5 bucks
01-27-2004, 03:31 PM | #11 |
Under construction!
Either way, Tim will never make his mind up.
Don't worry, I've been there too.
01-27-2004, 03:42 PM | #12 |
Insert Witty Text Here
How do you plan to control exactly how much it drops? The top and bottom of the spring both will only fit in one position. This means you have to remove one whole coil at a time.
Slonaker |
01-27-2004, 09:05 PM | #13 | |
01-27-2004, 10:06 PM | #14 | |
Under construction!
The front-end kit and body mounts won't affect the ride to that degree at all. The springs are "shot" f/r and your wondering why the ride is terrible...???
01-27-2004, 11:06 PM | #15 | |
01-27-2004, 11:12 PM | #16 |
duh! if you took a pair of shoes out of the trash, would you expect them to be comfortable? food out of the trash to taste good.
Tim, are you sure you can handle something this involved? i mean after all, you are the guy who cant tell if you have a TH350 or a TH400... Last edited by 1FaastC10; 01-27-2004 at 11:44 PM. |
01-28-2004, 12:14 AM | #17 | |
Under construction!
I'de be willing to put money on it.
01-28-2004, 12:44 AM | #18 | |
01-28-2004, 12:45 AM | #19 | |
01-28-2004, 06:07 AM | #20 |
5 day ban, learn to behave.
f*ck cutting them. torch em. heat em up until you acheive the desired sag. Dont even have to get out a wrench. Better make sure you know exactly how its going to react before attempting this little stunt though!
mike |
01-28-2004, 06:19 AM | #21 | |
