Old 01-12-2015, 12:41 AM   #4
MikeB
MikeB's Avatar
Re: engine color
Originally Posted by Jake Wade View Post
I know you said no black. I do all mine Black and I like the Duplicolor brand.
If its a late style engine with 1 pc oil seal, centerbolt valve covers, use a nice, uniform bead of RTV at the end seals of the intake, take your time sealing the timing cover, you wont have any leaks to worry about.
Very good point. It does have a one-piece seal, and I plan to use a FelPro one-piece neoprene pan gasket.
BTW, here are the engine specs:
1997 L31 block bored .030", decked to 9.005"
Eagle balanced rotating assembly with their basic crank, rods, and Speed Pro hypereutectic pistons.
Compression ratio should be around 9.6:1
New GMPP Vortec heads
GMPP HT383/RamJet 350 roller cam and latest LS2/LS7 lifters
Weiand 8121 low-rise, dual-plane intake manifold
Holley 0-80457SA 600 CFM aluminum carb
Ignition and exhaust to be determined
Trans is a rebuilt TH350 with TransGo 350-1 shift kit and stock converter. Axle is 2.73.
I'm shooting for a very torquey driver with reasonable pull in first gear, and tolerable revs at 70 mph.
Mike
1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress.
1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
