Old 01-14-2015, 12:24 PM   #1
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Re: 1972 3/4 4x4 rear end questions
Originally Posted by RedRoad View Post
I am pondering the same swap as well. If I could find some reasonably priced bearings for my 72 HO52 I would just rebuild it. While I had it out I would drop in a detroit and put in some 14 bolt axles
Ive heard that before but I got new bearings from rock auto, all timkens, for what I thought was a pretty good price. I think it was 100 or so. Can look at receipts when I get home.
Originally Posted by Seventy468 View Post
I should have specified its a full floating corp 14. We run them behind 700 hp big blocks and rarely have issues, figured it could handle a 300 hp SBC on the street no problem. And as far as why not find a 72 axle instead of 79? Availability. Used to find 3/4 axle sets all day for $250, and then they all dried up. Got lucky enough to find a good 79 donor truck with 3/4 axles and jumped on it. Had I realized the 3/4 axles weren't all the same for 67-72 to the 73-87 I would have looked harder and would have most likely had to buy one out of state and have it shipped to me. Around here a 72 donor truck goes for $2-3500, which is out of the question. HO 52.. isn't that a 3/4 axle? Im going from 1/2 ton to 3/4, or 6 lug to 8 lug. Obviously I didnt do my homework well enough and now im paying for it with time and labor, no biggie. I'll also have to go back and double check the front end now also.
Gotcha, thought you had the Eaton already.
In an effort to help anyone with looking for good info, I found thread today.
http://67-72chevytrucks.com/vboard/s...d.php?t=536119
There are some errors in that thread, particularly on the stud size and brake size on the 71 and 72 4x4 ho52 rears. 72 Had larger drums (12 x 2.5) And 71 had (11x2). Both had 9/16 studs.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 01-14-2015, 01:10 PM   #2
RedRoad
RedRoad's Avatar
[QUOTE=Vintage Windmills;7003196]Ive heard that before but I got new bearings from rock auto, all timkens, for what I thought was a pretty good price. I think it was 100 or so. Can look at receipts when I get home.
I would appreciate some part numbers.
RedRoad is offline   Reply With Quote
Old 01-14-2015, 11:37 PM   #3
RedRoad
RedRoad's Avatar
Originally Posted by Vintage Windmills View Post
I think it was $100 or so.
Please let me know where you found this price on the bearings, RA is the cheapest I could find but like I posted above the kit is $481.
I could get a 2010 14 bolt with factory disks for $250 around here and a rebuild kit for $152 and still be into it less than a rebuild kit alone on the Eaton.
