rebuilding my entire front end... advice
Ok, I'll be replacing upper and lower a-arms with new ball joints, drop spindles ( probably mcgaughys unless there is a better option), new tie rod ends, new shocks, drop springs, all new brakes, and all of the wheel bearings. What brands would you guys recommend for the bearings, drop shocks, springs, and spindles. The a-arms will be junkyard rebuilds. I have energy suspension bushings for the whole truck. Someone said to swap the pitman arm out while I'm in there. Any other suggestions. Gotta get this done because my front end is roaring from the bad bearing and old rusty brakes.
Re: rebuilding my entire front end... advice
If you do control arm bushings go with polyurethane bushings that use the factory sleeves, or you will regret it after a weekend of unnecessary work (ask me how I know). Sounds like that's what you've already purchased, the old bushings are really "fun" to get out.
Don't think you can beat MOOG for steering components and balljoints. For lowering components don't run anything off brand, a quick google image search will prove why you shouldn't go that route. I used western chassis parts for my build and they seem to build a quality, reasonably priced product. |
Just here to tinker
![]() Join Date: Jun 2008
I use Moog for all tie-rods, pitman, idler, and bushings.
The A arm bushings will kick your a*s if you remove the factory sleeves. Not fun at all. Best way I found was to get a 1/4" drill bit and drill through the rubber at as many intervals as you can. That helps weaken and break up the rubber to get it out.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
#4 | |
Second Moog parts. Put 'em in once and forget about 'em.
While you're doing all that, you might want to put the frame reinforcement in at the steering box.
Rich Weyand 1978 K10 RCSB DD. |
You can make quick work of the control arm bushings by cutting through the rubber with a hole saw, then knock out the metal with an air hammer.
^^^Never thought of that with the hole saw, but good idea!
Might as well replace the idler arm while you are doing it....
77 C10, 6.0LS/4L80E, 3:73 12 bolt. Boss 338's 20" x 10" w/ 285/50/20 rear. 20" x 8.5" w/ 245/40/20 front. Vintage Air. Full Autometer gauges recessed in factory bezel (Thanks bigblock73!) Gm Storm Grey Metallic paint "Cool ain't ever cheap and cheap ain't ever cool" |
Do we have any supporting vendors that are moog dealers? Advance auto has a sale going. I can get all the balls joints, inner and outter tie rods, the problem solver upper control arm rods shipped for around 360.
I bought all my front end parts from Rock Auto. I don't remember the brand though.
thanks!! Rock Auto is about $140 cheaper!
napa blue boots. they are the high end of napa. have had good luck with them when i could not get the moog parts as fast as i needed. still working good but for 10 bucks more i want moog. if for nothing else i better name lol
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph 1985 k30 "the ice cream truck from hell" no rust az truck 197-8??? c30 "ramp truck" 454 1978 monte carlo 350 350th with 2.73 gears. no rust. sc car |
You have to watch them at times though, they will ship from two or three different places and the shipping will rack up on you. I still saved money buying from them even after shipping though.
just got all the stuff from rock auto. Went ahead and got the idler arm and pitman arm too for less than the other stuff was at advance. Thanks guys.
#15 |
now i just have to figure out which drop spindles to get. Read a lot of bad about djm and some good about mcgaughys. any input?
#16 |
Advance use code trt30 or trt41. Break it up into smaller order so you get the max discounts.
#17 |
what brand wheel bearings do you guys use?
#18 |
American.
#19 |
HELL YEA! Timeken always has good bearings and done me good in my transfer case and SM465
Big Nate Carp. Local 224. Buy made in the USA! 03 F350 6.0 Daily Race Truck. 79 C70 366 Project Dump. |
#20 |
I narrowed it down to Timken or oem replacements. Definitely not getting ebay or auto zone bearings.
