Old 01-14-2015, 05:01 PM   #1
Mike C
Mike C's Avatar
Re: step side rear ends wider?
Where are you measuring from/to? Stepsides are the same as fleetsides depending on the year. 67-69 have the narrower rear. Sometime in 70 they switched to the wider so both wide and narrow exist. 71-72 is just the wider rear.
Leaf spring or coils? Do you have a pic to see if a different housing has been swapped in?
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 01-14-2015, 05:14 PM   #2
1moretoy
Measuring from the back of flange to back of flange. It is a coil set up with drum brakes.
1moretoy is offline   Reply With Quote
Old 01-14-2015, 06:04 PM   #3
Mike C
Mike C's Avatar
I just measured the 69 housing I pulled from my truck last week. It's close to 57" and is the narrower version.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 01-14-2015, 06:32 PM   #4
1moretoy
So being mine is a 70 and 59" it must be the wider version. I wonder how many people actually measure their rear end vs just listen to what everyone says.
