Old 01-07-2013, 12:18 AM   #26
Corts60
Just here to tinker
Corts60's Avatar
Re: 1/2dozen Burban
Just beautiful man! Well done!
Forgive me if I missed it, but what are your plans?
Old 01-01-2015, 10:44 PM   #27
hagenkustoms
hagenkustoms's Avatar
Re: 1/2dozen Burban
Can't wait to see the progress!
My build thread for the bagged 91
http://67-72chevytrucks.com/vboard/s...d.php?t=654179
Build thread for the slammed 52
http://67-72chevytrucks.com/vboard/s...=1#post7683427
hagenkustoms is offline   Reply With Quote
Old 01-14-2015, 10:11 PM   #28
1/2Dozen
1/2Dozen's Avatar
Re: 1/2dozen Burban
Well it has been awhile since I've posted. Took some time but I was able to complete the garage with some help from my Dad. It was built to the max size the city will allow, which isn't big enough. Anyway, it's time to bag a suburban! Plans are to lay out using full level 3 porterbuilt drop members, 22 inch transport wheels with stock hub caps, having the 292 freshened up and 700r4. Here are some pictures and I'll be posting more as I go.
Full pic of shop
At this point I was slowly raising the body to make sure everything was clear
Body is off and frame rolled back
Frame rolled back ready for fill dismantle
Tucking the 22s purchased from Alexander Speed. Lift was lowered as far as the lift arms would let me
5 total wanted a spare
Took frame down to the rails then power washed using a hotsy. Currently waiting on porterbuilt and in the meantime I'll coat the frame and clean up the mess I've made over the past few days.
66 suburban
51 Merc 2 door coupe
38 Chevy Business Coupe (gf's)
76 Airstream Sovereign
1/2Dozen is offline   Reply With Quote
Old 01-14-2015, 10:52 PM   #29
HemiChallenger71
HemiChallenger71's Avatar
Re: 1/2dozen Burban
Nice suburban and shop!
Here in MI in most areas a garage cannot exceed the sq. ft. of the house.
HemiChallenger71 is offline   Reply With Quote
Old 01-14-2015, 11:05 PM   #30
hagenkustoms
Re: 1/2dozen Burban
It's gonna be awesome !
Old 01-15-2015, 10:28 AM   #31
1/2Dozen
1/2Dozen's Avatar
Re: 1/2dozen Burban
Luckily we have a double lot so we could go max of 1200 sq. As long as it was connected. Otherwise, we could only use 30% of our back yard and peak of garage cannot exceed peak of house.
66 suburban
Old 01-15-2015, 06:25 PM   #32
TJ's Chevy
TJ's Chevy's Avatar
Re: 1/2dozen Burban
What's the plans for the 292? Maybe making it a street engine? Did it with mine. Great journey thus far. Nice project!
Old 01-15-2015, 08:18 PM   #33
1/2Dozen
1/2Dozen's Avatar
Re: 1/2dozen Burban
I'm more of the cruising type. Plans are to freshen it up with new gaskets, valve seats and rings then paint it stock color. If it needs more when opened up then I'll go from there. It only has 48k on it and for the 3k I've driven it seems to get around pretty good. Just tired of the small seepage of oil making it all dirty! Your 292 looks great! What all have you done to it?
66 suburban
Old 01-15-2015, 09:53 PM   #34
TJ's Chevy
TJ's Chevy's Avatar
Re: 1/2dozen Burban
A ton. lol Fully custom rebuild.
Lump port head...1.94 intake 1.60 exhaust valves. Roller rockers. Bigger valve springs, Bored .040 over with custom ross pistons, comp cam, fully balanced, zero decked. all the good stuff. lol
Old 01-15-2015, 10:34 PM   #35
1/2Dozen
1/2Dozen's Avatar
Re: 1/2dozen Burban
Sounds like money! 4k or more? 350-400 hp?
66 suburban
Old 01-15-2015, 10:43 PM   #36
TJ's Chevy
TJ's Chevy's Avatar
Re: 1/2dozen Burban
lol Not quite! The custom pistons make the compression at 9.5.1 and I didn't go to crazy on the cam..268 duration 218 @.050 .486 lift on a 110 lobe center. I'll be around 320 hp and 340 torque and $5000 perrty much covering it. Now if I went with 10.5.1 compression and a .550 lift cam I'd be seeing at around 350+ hp. lol
