Old 01-15-2015, 04:23 PM   #1
texasld
texasld's Avatar
Junkyard Carrier Bearing???
I have been searching for the carrier bearing for our trucks and I have come to the conclusion that I have a bearing out of the JY. The "custom bracket" on the bottom seems to really give it away.
1969 C10 SWB 5.3L LS, 4l60e, 2/4 drop (In Progress)
2015 GMC 2500 Duramax (Daily Driver)
1999 Jeep TJ
2010 Harley Street Glide
Check Out My Build!: http://67-72chevytrucks.com/vboard/s...d.php?t=617981
texasld is offline   Reply With Quote
Old 01-15-2015, 04:26 PM   #2
michael bustamante
michael bustamante's Avatar
Re: Junkyard Carrier Bearing???
yeah that doesnt look like one for our trucks
1967custom
michael bustamante is offline   Reply With Quote
Old 01-15-2015, 04:27 PM   #3
texasld
texasld's Avatar
That's what I'm thinking. Now I need to figure out what I'm going to do!
1999 Jeep TJ
Old 01-15-2015, 04:29 PM   #4
texasld
texasld's Avatar
1999 Jeep TJ
Old 01-15-2015, 04:41 PM   #5
michael bustamante
will the bolt holes line up with the holes in the crossmember on your truck? and if so will the shaft be pretty straight? if not you might have to go with the horseshoe style designed for our longbed trucks.
1967custom
Old 01-15-2015, 04:48 PM   #6
texasld
texasld's Avatar
Yep,
This one was out of my LWB converted to SWB. In the middle of the rebuild now. I'll take it to the local napa and see if i can find a bearing. I don't mind making a bracket for mounting to make the new on work.
If this is the same size, I'm in luck. I see how this one mounts to the top of the loop.
http://www.napaonline.com/Catalog/Ca...6FF_0329213478
But i'm usually not that lucky.
1999 Jeep TJ
Old 01-15-2015, 05:29 PM   #7
67c10rustbuket
67c10rustbuket's Avatar
That is an original carrier, some call it the HD or heavy duty carrier bearing. Much better than the flimsy hanger bearing most had. There was just a thread about this the other day with a replacement part number...
Here you go.
http://67-72chevytrucks.com/vboard/s...d.php?t=656307
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 01-15-2015, 05:41 PM   #8
67ChevyRedneck
67ChevyRedneck's Avatar
It's a SWB now? Get rid of it and go with a one piece drive shaft.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 01-15-2015, 06:27 PM   #9
cdowns
cdowns's Avatar
a dumb question but why not buy a brand new one at your autoparts store?? for the work to install one i'd much rather have a brand new piece in there to set it an ferget it
Old 01-15-2015, 07:29 PM   #10
Mike C
Mike C's Avatar
I just posted about that this week. I replaced mine with a new one. Here is the thread, I show where I got it from as well as the Neapco part #.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 01-15-2015, 07:41 PM   #11
burb71
Active Member
Thats is factory
Same as the one on my 1968 C/10 Big Block & my 68 C/20 Big Block
burb71 is offline   Reply With Quote
Old 01-15-2015, 07:58 PM   #12
Mike C
Mike C's Avatar
Yes, they are factory. But at least at O'reilly auto parts, they have two different parts in their system and not that one. But in my thread I linked above, find the Neapco part #.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 01-15-2015, 09:14 PM   #13
cdowns
cdowns's Avatar
that is my advantage for shopping local instead of mailorder I go in and see the parts that they have and I select the one that is right for the job that i'm trying to accomplish
Old 01-15-2015, 10:00 PM   #14
Mike C
Mike C's Avatar
No argument from me. But my point is that they do NOT show the HD carrier bearing as an option in the computer for my truck at the LOCAL parts store for me.
They show two different carrier bearings but neither one looks like the one I have (and the one the original poster showed here). That was the point in me posting that other thread this week so if somebody else had the same issue they could find one.
After much LOCAL and internet research, I finally found one and ordered it. Now that the part # is known and a manufacturer, you may be able to order from a local store.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 01-15-2015, 10:04 PM   #15
Mike C
Mike C's Avatar
Actually, the bracket on "the bottom" goes on the top and bolts to the crossmember. Here is mine installed in the truck.
Attachment 1350082
Attachment 1350084
Attachment 1350085
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 01-16-2015, 12:16 AM   #16
texasld
texasld's Avatar
Holly MOSES! This form does it again. So much great info. Thank you for all the replies.
I looked into getting a single made $300. If I replace the bearings and UJ's myself it will cost me less. If I ever to decide to go lower in the rear, I'll be ready for it. I will have to have this one shortened, quoted $40 to do that. Plus a balance.
I picked up a new carrier at the parts store on my way home, it's the smaller type. I think I can make it work.
The "bracket" tabs on mine have been broken off and re welded at some time. Wonder what caused that?
1999 Jeep TJ
Old 01-16-2015, 12:19 AM   #17
texasld
texasld's Avatar
Question Re: Junkyard Carrier Bearing???
I'm guessing you are talking about a new carrier assembly?
1999 Jeep TJ
Old 01-16-2015, 06:40 AM   #18
MikeyMan
Many, many years ago, I had that "Heavy Duty" bracket & carrier on a '70 GMC 1/2 ton.
The bracket broke at both those places near where it's riveted to the cross member.
I couldn't find that style bracket in the junk yards, and never thought about having it welded. I ended up finding the other style bracket and converted to the "hanging donut" type carrier.
I wish this website and the wealth of information here was available way back then.
MikeyMan is offline   Reply With Quote
