454 and BBC performance parts
I have bought a virgin block, never been touched with -781 heads, intake to pan.
Then I have bought from a guy I trust, a modified Holley 850 cfm carb, new Vic. Jr. Edelbrock intake, his worked -781 heads that have been surfaced, bowl blended, stage 2 port job, S/S 2.19/1.88 valves, Comp Cam springs good to .650 lift, over $1000 worth of work done to these, his Comp 294s solid cam, 294 adv with 248@.050 land .595 lift, Comp true roller timing chain, Harland Sharp full roller rockers, Comp pushrods..whole top end... Well, I ran into an emergency yesterday, and will sell for what I bought all this for. All you need is to freshed up the bottom of the 454, and you'll have another set of stock 781's as well with that, have the crank turned, re-size the rods, add pistons of your choice, you'd be set with a screamer motor. Will sell cheap. a good inexpensive way to have a 500hp motor with tons of torque as well... will cover freight if semi close... $1900.00 for everything |
driving is in my blood
I hope everything is ok tracy
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
Chevy Freak
454 stuff
Tracy, let me know if you are interested in selling the carb only. Thanks. Brian
69 GMC SWB, 350 70 Chevy LWB, 350 55 chevy gasser, 461 73 Camaro, 496 67 RS Camaro, 406 64 Chevelle, 588 71 Nova, 565 67 Camaro, 461 |
Project92 SWB stepside
Post a few pics if you can??
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
#5 | |
I have pics of the heads, intake and carb...I forgot your email address. email me at tfocht@kicker.com |
Glad you guys are happy with it. Let me know how it runs!!! Also if you guys need any new parts let me know as I have a few connections that I am getting into.
#7 | |
SOLD!!!
#9 | |
How do you go about stroking one of these??
#11 | |
AH HA!! So the crank is not a factory piece. Its a custom build??
#13 | |
Link does not worky!!
#15 |
#16 |
What has to be done to the block to accept this crank?? Also what size rods are needed??
#17 |
What is the casting number on this block?? 2 or 4 bolt cast or forged crank and rods??
