Old 01-17-2015, 10:58 AM   #1
Popcorn W
Popcorn W's Avatar
Rag Joint rebuild question
63 C-10 original manual steering.
Will this part work?
http://www.autozone.com/miscellaneou...ng/730051_0_0/
It's Dorman Help part # 31000
And according to AutoZone look up it's supposed to fit 63 and it's 3 3/16" like the old one I have. But looking at Advance Auto Parts site they say it won't fit a 63
Popcorn W is offline   Reply With Quote
Old 01-17-2015, 11:08 AM   #2
scottofksu
scottofksu's Avatar
Re: Rag Joint rebuild question
I don't know how accurate the AutoZone system is, but I've always had good luck with RockAuto.
Here's the link to their listing of the part specifically for your 63'.
https://www.rockauto.com/catalog/x,c...,parttype,7418
If you do go with RockAuto, always google "RockAuto Discount Code" and you'll save yourself 5%.
Conversely, you could always buy the AutoZone part and return it if it isn't the correct one...
Travis' Tribute Truck - 65 C10 Frame Up Restoration
http://67-72chevytrucks.com/vboard/s...d.php?t=495073
scottofksu is offline   Reply With Quote
Old 01-17-2015, 11:12 AM   #3
Popcorn W
Popcorn W's Avatar
Thanks Scott. I've ordered from Rock Auto before. They usually beat everybody's prices.
But I was looking more for just the rebuild kit. My steering box shaft clamp is suffering from the "52 year crud build up and I don't want to come off" virus.
If I get the kit I can rebuild it on the truck. I've been soaking the clamp in Kroil Oil for a couple days so it may break loose if I need to go that route.
Old 01-17-2015, 01:51 PM   #4
65 C20
If you go to the Suspension forum and do a search on Back to the Basics,
Tx Firefighter has done an excellent article on the topic.
65 C20 is offline   Reply With Quote
Old 01-17-2015, 04:06 PM   #5
Popcorn W
Popcorn W's Avatar
I did see that. But I didn't see him mention what year truck he was working on, unless I just missed it.
Old 01-17-2015, 04:22 PM   #6
dougf
dougf's Avatar
I bought the same thing from autozone and rebuilt my 66 C10 rag joint in about thirty minutes. Worked great.
dougf is offline   Reply With Quote
Old 01-17-2015, 04:56 PM   #7
franken
There was a post on some forum that said rebuilding rag joints is a bad idea since it torques on the rubber and the bolt will loosen. Might look into an early XJ steering shaft swap to eliminate the rag joint.
Old 01-17-2015, 09:53 PM   #8
Popcorn W
Popcorn W's Avatar
Thanks!
That story about a retired GM Engineer saying that? I'm thinking as long as the nuts are Ny-Lock nuts it should be fine, but I'm no engineer either.
Old 01-18-2015, 01:26 PM   #9
65 C20
He mentions that he was doing a mid 70's with power steering.
Also mentioned that they were messed up with thier applications.
I think that if the disc size is the same you should be OK.
He said that he re-used as many of the original bolts that he could.
