Old 01-17-2015, 09:13 PM   #1
hilltop55
hilltop55's Avatar
67 with leaf spring
I'm looking at a 67 Shortbed that the owner says was converted to rear leaf spring??? Has anyone ever heard of this and what should I look for when I check it out this week. Thanks. Lou
hilltop55 is offline   Reply With Quote
Old 01-17-2015, 10:26 PM   #2
Mike C
Mike C's Avatar
Re: 67 with leaf spring
Most Chevy's were coil and most GMC leaf, but the other setup was optional on both.
My '69 short step is a factory leaf truck and there are plenty more out there.
Hopefully it's a factory leaf truck and not somebody's home job...
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 01-17-2015, 10:26 PM   #3
JJR
JJR's Avatar
Mike C beat me too it.
I haven't personally seen any trucks that were converted from coils to leafs but anything is possible. Since rear leaf springs were a factory option for Chevy's, my guess would be that the truck originally came with the leafs and he thinks it must have been converted since some people think that all 2wd's came with rear coils/trailing arms. Does he known for sure it was converted?
FOUNDING MEMBER OF THE DRUM BRAKE CLUB
Second Owner 70 C-10
Second Owner 93 GMC C1500
Third Owner 99 C2500 Crew Cab Short Bed
JJR is offline   Reply With Quote
Old 01-18-2015, 12:24 AM   #4
michael bustamante
michael bustamante's Avatar
Look to see if shackle mounts are bolted on or rivited. Bolt on means its been converted most likely
1967custom
michael bustamante is offline   Reply With Quote
Old 01-18-2015, 11:37 AM   #5
factorystock
factorystock's Avatar
Rear leaf springs on a Chevy 2WD (C10-C20) was a SPECIAL order option in '67. Check the SPID decal in glove box, it will be documented there, if the factory installed them.
factorystock is offline   Reply With Quote
Old 01-18-2015, 07:34 PM   #6
hilltop55
hilltop55's Avatar
I'm going to look at it this week I'll let you guys know. Spid is gone and cab was totLly redone and stripped which worrys me a little since there are no pedal, heater,etc.
