Old 01-19-2015, 02:57 PM   #9
gmachinz
Re: Can you hook Cruise Control up to Edelbrock 1407?
No, I don't think you need that bracket. Your factory bracket is actually a combination cruise control, throttle and kickdown all made into one bracket which bolts to the intake AND has a spot to route the power brake line through to the carb as well-that vacuum line you may need to re-route or make another like it.
But, if you are retaining your stock bracket, the Eddy cruise control kit will work with your OEM setup. This way you have two ways to adjust cruise level length-using the supplied kit and threading the cruise control end up or down. It may take a few trial/error drives to get it dialed in.
gmachinz is offline   Reply With Quote
