01-19-2015, 11:06 AM | #1 |
What do you think of my drive line Angles?
I have a 69 C10 long bed with a 350 crate and 700R4 transmission. 3.07 rear end. I just finished installin 2 1/2 dropped spindles and 4 inch dropped rear springs. I think I may have a slight vibration under hard acceleration that I didn't notice before installing the dropped rear springs. I had the front end aligned and tires balanced two days ago. To eliminate drive line as the cause I determined my two piece drive line angles as set forth below.
What do you think of them? do they look acceptable? If not why not. Thanks Sorry I couldnt figure out how to rotate immage |
01-19-2015, 12:34 PM | #2 |
Re: What do you think of my drive line Angles?
I think it looks good. How does it drive? Any vibration?
01-19-2015, 12:40 PM | #3 |
Gotta love those angles of the dangles....
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
01-19-2015, 01:03 PM | #4 |
I have s slight vibration under full throttle. Nothing at cruising. Could be something other than drive shaft alignment.
Just trying to eliminate all possibilities. |
01-19-2015, 01:42 PM | #5 | |
Msgt USAF Ret
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
01-19-2015, 02:17 PM | #6 |
Your centre bearing is where the problem is. The u-joint there has no working angle.
Here's a link to figure it out. http://www2.dana.com/pdf/J3311-1-DSSP.pdf And another one. http://www.drivetrain.com/parts_cata..._problems.html |
01-19-2015, 03:02 PM | #7 |
Looking at that again, Geezer right. Although the front and rear joint will cancel themselves out the acceleration and deceleration the shaft are likely transferred to the bearing and frame.
01-19-2015, 09:05 PM | #8 |
you guys are such geniuses. i had one hole in the carriage bearing bracket left and i moved it up to that hole and solved all my vibration problems. moreover i checked my angles angles he 2nd shaft was up 3,7 not down.
thanks for your help. |
