#26 | |
![]() Join Date: Mar 2012
Re: Quick Trans swap question
I had to modify the AC bracket so I could move the passenger motor mount forward. I raised my motor mounts up 5/8" to give the AC more clearance. No oil pan issues. The LT1 is basically the old SBC block. I used my old headers from the 350. I bought a radiator off ebay but a stock one will work. My build thread has some more info. Thanks. Tim
Sold the 63 and have a 68 now. 63 ![]() LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18 http://67-72chevytrucks.com/vboard/s...d.php?t=544174 |
#27 |
Trsmotrhed,
I just got back from Los Angeles with my "new" LT1. I'm gonna end up re-gasketing the whole thing, and am looking into doing an LS style ignition swap. you Said your motor mounts were the same as the stock SB ones, right?
2013 Malibu LTZ 1996 C1500 4.3/5spd 2wd |
#28 |
Yes the stock ones will work. I had to grind a little in the ac bracket to make them work so I could move them forward. You'll see the different holes.
