Old 01-19-2015, 12:39 AM   #1
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
What did you get done 1/18 /15 football championship edition
This week I got the plow assembly on my truck to find out that the pump wont release to allow the plow to go down that goes to the shop tomorrow.. Maybe this thing will work before spring when I don't need a freakin plow. I also got the left side u joint into the front end of the axel. Eventually I need to get some ball joints and the other side done
Im STILL trying to find parts for the project truck
Finally I got the Nissan starter issue figured out bad ground
How about you all??
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 01-19-2015, 12:54 AM   #2
Drizzle
Re: What did you get done 1/18 /15 football championship edition
Removed and painted all interior plastics from red to black, bolted the rally center adaptor kit to my rims "waiting for centers to arrive in the mail" and replaced the hose coming from vacuum modulator to intake. That one wasn't planned. So drove to advanced auto in first gear darnit. Luckily I was really close by.
Drizzle is offline   Reply With Quote
Old 01-19-2015, 01:11 AM   #3
enaberif
Almost buttoned up and ready to start... Just a few more small things.
enaberif is offline   Reply With Quote
Old 01-19-2015, 12:40 PM   #4
SCOTI
SCOTI's Avatar
Installed headliner, new dome lights, & replaced all the power window motors.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-19-2015, 12:55 PM   #5
Rich84
Rich84's Avatar
Watched football, drank beer, stirred the sauce..Took the battery charger off the Mercedes and put it on my truck. Really need to get some Battery Tenders.
Rich84 is offline   Reply With Quote
Old 01-19-2015, 02:34 PM   #6
pontiac6269
pontiac6269's Avatar
Wired up a toggle switch for the 700r4 lock up converter in the 81 C20 and took it for a test drive.
Eric
2001 Ford F350 EC dually 7.3
1981 Chevy C20 to K20 350
1978 Oldsmobile Cutlass Supreme 455 Pontiac
1969 Pontiac GTO 400
pontiac6269 is offline   Reply With Quote
Old 01-19-2015, 03:06 PM   #7
riz
Damn near broke my wrists clapping when the Packers choked against the Seahawks.
RIZ
riz is offline   Reply With Quote
Old 01-19-2015, 05:17 PM   #8
gasmn1620
got a set of doner a-arms pulled from the junk yard, broke down, and ready for sand blasting and powder coating. Suspension parts should be in this week and I'll be installing all new suspension front and back, wheel bearings, and drop kit within the next 2 weeks.
gasmn1620 is offline   Reply With Quote
Old 01-19-2015, 06:22 PM   #9
Shifty One
Shifty One's Avatar
Did the fishing line, 3/M eraser thing to the wasted molding on the olde V20
Ran out of daylight, but I need to compound the area where the molding was still.
Old 01-19-2015, 09:49 PM   #10
NJ C10 Guy
Started tearing out everything to remove my motor. Today just the air cleaner, carb, alternator ground wire, and fan. Sill need to get the distributor and radiator pulled, and all hoses/wires. Pretty sure i spun a bearing, which sucks. Gonna take the motor apart and inspect, take it to the machine shop and see what kind of damage was done. Then, it's either a rebuild or a crate motor for me...
Bob, you don't happen to have an engine crane do you?
NJ C10 Guy is offline   Reply With Quote
Old 01-19-2015, 11:18 PM   #11
old Rusty C10
Not only an engine crane but a motor stand too
Bob
I hate cancer!!
Old 01-20-2015, 09:58 AM   #12
rs74
rs74's Avatar
Put a new set of Thrush turbo mufflers on the dually. Alot quieter now. The bottom casing on the drivers side was completely gone.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 01-20-2015, 12:30 PM   #13
nonstop
I put on a gear reduction starter (the thing is great!) and was able to get dual piston calipers mounted up on my truck.
nonstop is offline   Reply With Quote
