01-17-2015, 12:25 PM | #1 |
wheel problem
I running a rally wheel for camaros on my truck. the front wheel is a 15x8 with 4" b.s and an offset of -12.0mm. Im having clearance issues with wilwood brake calipers hitting the bead of where the face of the wheel is welded to the ring of the wheel. I was wondering if I was to buy another wheel that is a 15x8 with 5" b.s an on offset of 12.0mm if this would work?
01-20-2015, 10:30 PM | #2 |
Re: wheel problem
Ttt
01-21-2015, 08:54 AM | #3 |
Re: wheel problem
It may not help if the issue is with the the face of the wheel. That part could be the same with just a different outer ring. A call to the wheel manufacturer may be in order.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
